Finally got this installed, so I can report that the action of the tool change is smooth and easy enough that I can swap out an endmill while the power is off w/o moving my HDZ or the gantry at all:
Test cuts tomorrow, then I’ll have to arrange all of the endmills I use, measure the length of their stickout, and work up dust collection options for all of them.
Just to touch base — I’ve been doing a lot of testing, which has involved a lot of tool changes, and the Mafell Quick Change Spindle has been working perfectly.
Did have one disconnect which I’m attributing to the transformer — hopefully I can get things re-arranged a bit so that it’s not so close to the electronics.
The other consideration is that the Mafell FM 1000 WS version is no longer carried by Timberwolf Tools — apparently it will be replaced by the FM 1000 PV-WS model:
(which brings us full circle)
It would be pretty cool if someone could document what is involved in connecting that to the BitRunner connector on a Carbide Motion board — even cooler if Mafell would work up a 110V unit.
sounds like it has a “0-10V portal control”, so it would probably boil down to procuring the correct set of connectors, and a 0-5 to 0-10V voltage shifter to insert between the bitrunner connector and the portal.
You will need to set the min/max spindle speeds, some light unverified googling says $30 and $31 will set this. This will then control the PWM output for a given RPM and “map” it appropriately.
I was warned when the step-up/down transformer was suggested that it was a heavy-duty unit which could potentially burn a house down (or maybe they meant that no using this could cause that)…
anyway, I usually unplug/turn off the dehumidifier when running the CNC, but the other week I forgot — as near as I can figure, both it, and the spindle came one at the same time, followed by “the magic smoke” and half the outlets in the basement going dead.
Turns out the basement wiring was bridging from one outlet to the next using the outlets to carry the current over, which was too much for the outlet feeding the outlet the dehumidifier was plugged into — burned out the outlet, but the appearance was quite terrifying.
An electrician pretty quickly sorted out, and we scheduled a return trip to wire up half the basement outlets on their own circuit, and to put in a separate 20-amp circuit for the spindle/vacuum — finally got all that done this morning, so back up and running.
Recommendation: if using a spindle which has the potential to make a very heavy current draw, get a separate circuit run for it, and future-proof it by making it 20 amps.
I’ve drawn up an adapter plate for my SO5 Pro, so hopefully this will get moved over presently, then I’ll set up my XL for metal-working (don’t want to scratch up my nifty Sweep Pro on my SO5 Pro) and will set up my SO3s for cutting tropical woods outside.
Do I need the pro version of Carbide Create?
I downloaded the files and tried to open them, the page is just blank and there are no toolpaths or anything.
Modified the file to what I believe is the correct hole spacing for the mounting to the SO5 Pro plate — measure and check against yours before committing:
