So I am going to have a spare 2.2kw water cooled spindle and Vfd. I had another failure and the amazon seller is replacing it by shipping a new spindle From China. God only knows how long it will take. So in the meantime I ordered another identical spindle and vfd so I can get caught back up on orders.
I am on the fence as to whether or not I’ll be keeping it or returning it with the new spindle when it arrives.
So if I were to keep it I can’t just have it laying around. My mind doesn’t work that way. Do what if I built a lathe to mount either to the table or in front of it in order to turn table legs and such. I could make around a 30” long turned section with it if I hang it out the front enough.
So is it durable using fusion 360 to design a turning and have the machine only move on the z and y axis and treat it like a cnc lathe?
I don’t have to have the shapeoko control the rpm. That’s easy enough to set an rpm manually for the turning.
I’m just curious really if I can do it with a couple pieces of extrusion a lathe chuck and a live center I might have it a go.
