Note that they Y-axis is twice the specified dimension and that the origin is set to “Center-Left” — this is to facilitate setting the job up as two-sided.
Next, it will be necessary to consider workholding and assign toolpaths.
Since the wrist rest bottom has a flat bottom, we will cut that first, and then when rotating, affix that in place using double-sided tape or painter’s tape and cyanoacrylate:
It will also be necessary to register the flip in some way — a pair of dowel holes should work well, say 5/16" (8mm):
