Steps — you need to model it a second time to add the further rounding.
See the attached.
See the attached.
When I open yours, it looks like your image. Clearly this is cockpit error on my part.
No way to go back in and see the modeling parameters after hitting DONE?
Unfortunately no, but you can see the settings I used by clicking on the relevant image above.
Ok. Finally got it. I’m going to give it a whirl on the machine and see what happens. I thought this would be easy. Yikes. I do see what you mean about putting it somewhere else, push/pulling the faces and exporting as an STL file.
I wish that OpenSCAD was better at organic modeling (or more precisely, that my grasp of math was such that I could make use of it so as to do that sort of thing).
I bought a license for:
but haven’t found much occasion for working with it.
Arguably, I should put more effort into Alibre, but it’s not convenient for me, since the only machines I have connected to mice are my MacBook, which is in my basement den and at which I have to work for my day job, and a Raspberry Pi which is running a copy of the Shapeko wiki/forum.
“that my grasp of math was such that I could make use of it so as to do that sort of thing”
I’m drinking tea and it just came shooting out my nose. YOUR grasp of math? LOL. You’ve got a better grip on math than anyone else I know!
Unfortunately, my high school couldn’t find anyone to teach calculus for my junior year of high school, instead there was an “Advanced Math” class which was essentially me hanging out in the computer room writing and playing games, so Stanford wasn’t an option, and my math tops out at HS trigonometry.
I’ve been working to address this — there’s a series of books which have helped:
which I’m a bit over two-thirds of the way through — but it’s quite amazing what some folks can do w/ OpenSCAD:
https://www.raphaelluckom.com/posts/bezier_curves.html
and I’m hoping to eventually arrive at a point where folks can do similar things with:
Of course, I’d probably drop all that like a hot rock if a certain integrated CAD/CAM program got scripting… (or if I could wrap my mind around using Alibre and make use of its scripting)
Hi Will. Made some progress. I modeled it in Vectorworks and saved it as an STL file. When I import it into CCP, nothing shows up. If I look at the file in Preview, it shows as a 3D model. Any thoughts? Is there something special about CCP and STL files? Admittedly, I know nothing about them. LOL.
Utensil Outline FInal Extrude test.stl (63.4 KB)
Update: There are two kinds of STL. CCP likes Binary, it seems. This one worked to import.
Utensil Outline FInal Extrude test binary.stl (10.8 KB)
The first file also had to be repaired by Microsoft 3D Builder.
Hi Will, Now that I’ve got the model done, how to I actually machine it? LOL. I know I’ve got to flip it over to do both sides but that’s all I understand.
In VWX it’s 13 inches long. When I import it, I see in the import box, there’s a height of .1181 and the XY scale imports as 1.076 for some reason. What do those mean? Is it scaling to match the stock size, which is set at 14"?
When I go change the stock size, it doesn’t seem to change the model size, just the outline. Not sure how I can machine it like this taking into account clamps and a corner to hold the workpiece. There’s no place for the bit. Same goes for centering it on the stock. I get the following images, which I don’t understand.
I’m hesitant to start machining because I don’t want to destroy my clamps and or corners.
Then here’s what the tool path shows. Which is confusing, also.
First consideration is where the origin will be for the first side, and where it will be for the second.
See:
I consider the Essentials clamps a consumable — buy a spare pack and don’t worry (esp. if you’re w/in your 30-Day “Mistakes are on us” period: For 30 Days, Mistakes are on Us )
The way I would do this is:
Figure out where the centerline of the part is by drawing a rectangle from a node to the corner:
duping it and moving it register with the matching node at the other edge:
Selecting both to get the overall dimension:
and set my Job Setup and Stock to match:
Then cut the first side thus, but for the second (since this is top/bottom symmetrical), re-orient the part by rolling it 180 degrees from front–back and set the origin so that that same corner will be used for origin of the second operation:
For the geometry associated w/ the toolpath, offset to the outside by the radius of the tool you will use for finishing and roughing plus 10%:
(if using a 1/8" for 3D Finishing)
(if using a 1/4" for 3D Roughing)
Draw in geometry along the centerline for a sprue:
ensuring it is aligned w/ the center of the part/stock.
Then remove the part from it using Boolean Subtract (ideally leaving the original part behind):
OK
Delete the original rectangle:
Select the trimmed rectangle and duplicate it:
subtract each from the offset geometry, either using multiple Boolean operations or (easiest) Trim Vectors which are then joined back together:
Remove what is not wanted:
Ok
OK
Join Vectors
Yes
Repeat for the other, arriving at:
Select the outer geometry for roughing:
and the other for finishing:
(adjusting the stepover as desired for finish)
Hi Will,
You’re going to hate me, but I don’t understand anything you’ve described above. I thought once I had an STL model, I could just machine it, once on each side, as described in the two sided milling video. What are all these other steps for? I am completely lost.
And before we dive into the above, I still have a basic question:
Why does CCP change the size of my part? How can I even begin to make the part when CCP changes the size upon import? I’ve watched the STL video by Kevin and I don’t see any of this mentioned when milling from an STL. I’m so sorry to keep bugging you, but I am at a total loss on how to get this object milled.
Sorry!
The extra steps are necessary so as to have a “sprue” for the two-sided machining operation — probably they could be added to the 3D model easier.
Carbide Create Pro has 3D modeling like to that in Vectric Aspire which seems to be best suited for decorative use.
If you want something to come in at a given size you will need:
See:
I suspect you’d find MeshCAM a bit more workable for this:
Reading that Tutorial I see that they took an STL file and just cut it out. It looks like a simple 2D shape. I see that they added the bit diameter plus 10%, but I don’t understand why. Why do that step when I can just have CCP do a contour cut around the outside of the current object?
And what does a sprue actually do? I watched that video again and don’t see any mention of it.
I’m totally lost. If I go in and scale the STL to the size I would like (which is exactly the size I’ve created it in VWX) then try to do a 3D roughing toolpath, I just get an “EMPTY TOOLPATH” message. If I leave at the in correct size (scaled up by 1.076, that the program chooses) and then go to try a rough tool path, it works. I have no idea what I am doing wrong.
Here’s how it comes in:
The extra geometry and space around the part is to allow cutting out without burying the tool in a slot.
A sprue is an attachment point which keeps a part in place, whether in molding or for a 2-sided operation.
When I open that file it has to be repaired:
Once it is repaired, I get dimensions of:
Importing that we get:
We change XY Scale to 1.0 and Height to 6.4 and Apply:
We then select the outer geometry and cut a 3D Roughing toolpath:
then a 3D Finishing toolpath with a very fine stepover:
to arrive at:
Hmm. Something is very odd here. My STL imports just fine into CC. But just to follow along, I’ve set my stock size to match what you found.
I think I am following your steps, but it seems anytime I scale or change anything , I get this empty toolpath. Is there a step I am missing?
You didn’t change the scale to 1.0 and you’re not selecting geometry larger than the model to associate with the toolpath and you’re not choosing a tool other than #102 DEFAULT.
See attached.
STL_import.c2d (1.1 MB)
Note that you can click on the screen grabs here to see them at full size on your screen — that should make it easier.
Maybe @KevBarn14 can do a video you can follow along on?
EDIT: a further concern is that in the above file, the part is cut all the way through from the top — no sprue — it would be better to model as before, adding half the thickness.
