Hello
I live in the Netherlands and I have been working with a Shapeoko 4 for a month, I upgraded it with a 2.2 kW spindle. Now I’m working on the feeds and speed for my tools, but now I’m running into the problem that I can’t find anywhere what my maximum feedrate is from the Shapeoko 4. I understand this is stuck in the GRBL. But how much is this then?
I hope someone can explain this. Thanks in advance.
The settings for a Shapeoko 3 are noted at:
https://docs.carbide3d.com/software-faq/shapeoko-3-default-grbl-settings/
there was some discussion about more aggressive settings at:
which were implemented. To see the specific settings open up the Log, then go to the MDI and send $$ to the machine, then check the Log for what your machine is set to.
