Hi,
I would like to know what is the maximum speed of movement of the router without cutting. Only the movement between two pieces of wood for example.
Thank you :=)
Bobi
Hi,
Thank you :=)
Bobi
Hey Bobi, the max rate for the shapeoko 3 XXL is 10,000 mm/min for X and Y, 1,000 mm/min for Z
On second thought, it kind of depends on what Z axis you have, 1,000 mm/min for the Z plus and 5,000 mm/min for the belt drive
The maximum feedrates are defined by your $$ settings.
$110, $111, & $112
You can always change them, but you’d want to test if you’re trying to max them out.
For more on changing these see:
Hi everyone,
Thanks a lot for your answers !
I will try soon
have a great day,
Bobi
