2" long x .125" wide, Split length .4", Tip width .002" , angle 30 deg
In carbide create while adding a new v-mill to my tool library where it says to put the tool diameter in if I put .125" in the box wit flute length and angle my pocket tool paths are almost non existent.
If I put the tip width in the diameter box then it looks good. Is this the right way of doing this?
I am trying to engrave some brass to make rings out of and i have had this question on my mind ever since.
Also if someone could help me calculate the speeds and feeds for this bit it would be appreciated.
Here is some examples of how they turn out with the .002" tip width in the diameter box. Once again I am using pocket operation. Also for that bit size the speeds and feeds do not automatically set or will cause errors if not adjusted manually.
These look great! Just curious if you’d had any new break throughs with engraving since you posted this. I’m about to order some small bits to start engraving and I have an idea just not sure exactly what to get and then there will be all the trouble shooting with CC like you were running in to. sigh…
