Sorry if this has been asked before. Would mounting the spindle/router higher in the bracket lessen side twisting forces on the machine when cutting, leading to more accurate cuts?
It sure helps reducing vwheel-related deflection, see this thread from @LiamM
So it will help front/back deflection, and there is no downside (as long as you can still reach/cut deep enough for the job at hand, and possibly to probe the bitsetter if you have one).
