Movement just stops
(Michael Oakley) #1
I have had a couple of cases where the spindle movement just stops.
I do a Pause and a stop then run again and it goes.
What may be causing this.
(Michael Oakley) #2
pausw and stop do not work either only a switch off
(William Adams) #3
Most likely this is caused by EMI:
https://wiki.shapeoko.com/index.php/Electronics#Recommendations
If you continue to have difficulties, let us know what you’ve tried at support@carbide3d.com and we’ll do our best to help.
(Luc) #4
Yep, I have that when my dustboot and dust extraction is working. At the moment, the humidity level is very low in my shop so I expect that the static electricity buildup is the cause. When I unplug the vacuum, I do not have the problem.
I just purchased some copper wire and I will run a separate ground through the vacuum tube and another ground on the spindle and the frame.
I hope this will address the issue but I will have to run some tests.
Job stops in middle of machining
(system) closed #5
