Thank you, the fog is starting to lift. So that area above the start depth, what you called
So that area got machined properly (at the right angle) but you could say “by accident” because Carbide Motion plunged through that area thinking it was air (not wood)?
I’ll attach the two files I am going to try tomorrow, if anyone cares to look over my first attempt.
Pocket that will be 1/8 (.125) deep, and a Plug that hopefully fits .10 into the pocket with .15 sticking out.
Thank you @neilferreri, @fenrus and @Julien… I now understand.
The results matched how my mind had interpreted your instructions.
I was able to produce a .125 pocket, with a plug that fit (roughly) .1 inch inside the pocket.
