I have been moving my XXL to a new workshop, and building out my dream upgrades while at it. One thing I have have always drooled over is the rear automation cabinets holding all the DIN mounted electronics for high end CNCs (Hass etc). So figured I would dabble a little in that space (i.e. be a poser) since I wanted to do proper E-Stop, Feed Hold, etc anyway. Here are some pics (still a work in progress obviously).
Here you can see the controller cabinet on the wall, and the button box for E-Stop, Feed Hold, and Vacuum On/Off:
Here is view of the other side of the enclosure with the 220V mains disconnect switch. Still to do is running out the 12V/GND cable for my smaller water pump enclosure I built (will create a separate post on that), as well as the spindle power cable. Also seen is the exhaust port for the bottom mounted fan.
And finally the fun stuff with details on the controller enclosure internals:
I replaced the Carbide Motion power supply with a DIN mounted one (24VDC/5A). The 12VDC supply is for running the spindle water pump, power relay, vac relay, and enclosure fan. The 220V Contactor is basically a relay on steroids, and allows the E-Stop button to kill power to the VFD (as well as killing power to the Carbide Motion board via the power relay). I also have a Feed Hold button that I will use as a softer/nicer emergency stop. I didn’t label it, but at the bottom is the 140mm fan for cooling.
One thing I went through great pains with is ensuring ALL grounds in the system are home run back to the central ground location in the cabinet. This includes all electronics and shielded cables. This is super important for system stability. I completely rebuilt all the stepper cables with double grounded 18 gauge cables. As well as shielded cabled for the limit switches.
I also went so far as to isolate the Carbide Controller PCB from the chassis (with felt pads), to ensure the only path to ground was through the power cable that feeds the board (and runs to the central ground). On another note, not sure how well its going to work yet, but for cooling the board I mounted it to some large finned heat sinks (with thermal paste), and have the cabinet fan blowing right on it.
I am currently working on cleaning up my circuit diagram for all this and will post it if anyone is interested.
Well, see , what you did there was post some damn sexy pictures. Gaaa, I can hear my credit card crying from here.
