Need help in finding the right settings for a 1.8mm endmill milling brass (first endmill broke)
Hello,
up to now my endmills only broke when I made a mistake setting the z height and the tool crashed into the stock. However, today, I tried to mill brass with my new 1.8mm endmill (2 flutes) and unfortunately the endmill broke on the second pass slightly after the plunge.
I am still pretty new to CNC machining and want to understand what I did wrong here and how I need to change my settings in order to avoid breaking the next endmill again.
Here are the settings that I’ve used and which resulted in a broken endmill:
Although the pass depth is set to 0.1 mm for this tool I’ve changed the number of passes for this specific job to 3. So each pass removes 0.067 mm.
I did a bit of research and for the second try I would adapt the following settings:
spindle speed: 24k
feed rate: 500 mm/min
plunge rate: 125 mm/min (I’ve found that it should be ~25% of the feed rate)
this gets me a chip load of 0.01 mm
What do you think about that?
Thanks,
Bernhard
Pretty sure Winston in this video (I think?) mentioned doing things at .8 compared to what aluminum has for feeds speeds.
Winston on a different video using the shapeoko had (https://www.youtube.com/watch?v=8FA12Q0DMv8&t=56s):
112-Z
18K rpm
320mm feedrate
.15mm DOC
Seems like your feedrate is a bit high comparatively, even though your depth per pass isn’t as deep.
I have milled brass with 1mm and 0.5mm bits. After a few bust bits i invested in https://hsmadvisor.com/ which after a little learning curve has served me well if, at least for me and to my liking, is probably conservative with feeds, works well.
These appear to be very conservative settings. Could it be they are so conservative they are just rubbing rather than cutting? If you have a login, check provencut recipe 978.
The other thing to so check the runout on the shank of your cutter. It could be high due to poor collet, dirty collet or spindle bearings.
A word of warning here: I found these tools (I bought both HSM Advisor and the thing that Carbide3d is pushing in their website via popups as well, which was even worse) to be somewhat unhelpful. Or, more precisely, the results I got from them ranged from somewhat-reasonable to downright impossible.
One issue is that the spindle on the Nomad has unknown characteristics and reducing the power will not account for easy stalling. So these tools can easily generate numbers that are way too aggressive and you’ll stall in corners.
Another problem is that these tools seem to be geared towards metal machining. I haven’t actually checked their metal predictions, but for non-metal stuff my experience wasn’t good. They should remove Acrylic from their materials list, because their numbers for acrylic will never work (you’ll melt the material). For HDPE I was able to generate numbers that looked all good, but were impossible (spindle stalls). For tooling board it’s a mixed bag: sometimes they’ll hit the right numbers, sometimes not. Sometimes I have to slide the “speed” slider all the way down to 0.25x in order to get cut parameters that will work on the Nomad, sometimes not. Even for hardwoods I ran into spindle stalls with “green” numbers from HSMAdvisor.
G-Wizard was even worse, and I am really not sure why Carbide3d is promoting this tool in popups on their site, no less. I never found it useful with my Nomad.
Now, this might be better for metals, I’m just posting my experience here.
The resources which I usually recommend on this are:
  • the defaults in Carbide Create — these are quite conservative, but work well as a starting point
https://shttps://www.youtube.com/watch?v=mhqjhD0XJl0hapeokoenthusiasts.gitbook.io/shapeoko-cnc-a-to-z/feeds-and-speeds-basics
and the videos at:
which @Radiation noted.
Another resource is:
from the company which @TDA works for.
I have been trying GWizard but haven’t gotten the hang of it yet. Too many variables and I don’t know which are important to hold constant.
The first few things I tried it suggested 30,000 rpm on the router and 120ipm for an .125” cut in walnut. That seems pretty agressive but maybe I didn’t have things dialed in properly.
