So I ran a job this morning with my BitSetter and had no issues. Loaded my ¼" probing blank, and tried to initialize, but this happened.
How do I fix this?
How do I fix this?
Thanks for the reply, @Julien, but that link is dead (for me at least).
I wouldn’t even know how to enable soft limits, and not sure how it would have happened in between jobs…
Settings–>Show Log
Then click in the MDI and send $$
You should see a string of settings starting with $.
@Julien and his secret thread suggested your $20 might be 1.
Sorry for the broken link, I meant this thread:
It may or may not be the same, but it’s easy enough to check: as @neilferreri said you can open the MDI tab, type “$20=0” (without the quotes) and click Send, then retry machine Initialization and see if it changes anything to your problem.
I agree it’s quite unlikely that it changed between jobs, this is just to cover your bases, to not spend time searching for another reason in case it would turn out to be just that setting.
$0=10
$1=255
$2=0
$3=6
$4=0
$5=0
$6=0
$10=255
$11=0.020
$12=0.010
$13=0
$20=0
$21=0
$22=1
$23=0
$24=100.000
$25=2000.000
$26=25
$27=3.000
$30=1000
$31=0
$32=0
$100=40.000
$101=40.000
$102=40.000
$110=10000.000
$111=10000.000
$112=5000.000
$120=500.000
$121=500.000
$122=400.000
$130=845.000
$131=850.000
$132=100.000
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
$G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 M56 T0 F0 S0]
ok
So $20=0
But I did disable the BitSetter and manually zeroed because I had to run the job. Would that make any difference?
Mmh. Just to clarify, did you just type “$$” in the MDI or did you also try my “$20=0” line in there ?
With things as they are now (with $20 set to 0), did you have a chance to re-enable the BitSetter and retry if the problem is still there ?
There should be no impact of temporarily disabling the BitSetter, that’s fine.
If the problem is still there when the BitSetter is enabled, my next moves would be
Just typed $$, didn’t send any config change.
I did just turn on my machine and re-enabled the BitSetter, send the configs, and it worked fine. Good, but I’d rather have known what happened for certain.
Guess it’s back to work and we’ll see how it goes today.
Ok, so for some reason your $20 setting must have be set to 1 when the problem happened. Do you use a laser by any chance ?
No, not yet…twenty characters
Ok, I was asking because sometimes switching back and forth between software for different uses of the machine involves macros that set/reset GRBL parameters to different values.
If you did not change anything in your usage of the machine, then I have no idea what could have set that $20 param to 1…but hopefully it will be ok now.
