I tried to add a new tool to the library. A genmitsu Flat Nose End Mill of 3.175mm
But whenever I use a comma (3,175) I can’t add the tool.
When I use a dot (3.175), the input is acceted and the window closes, but when I look at the Cutter information window, all fields that have decimals (and thus dots) are set to zero.
So using a comma is not possible and using a dot gives the wrong result…
