Or, if you have non-mechanical proximity switches, you can check they’re working by holding a metal screwdriver, for example, close to the limit switch (with the machine switched powered on) and look to see if the red LED lights up.
That 'orrible grinding noise? Been there, done that, got the T-shirt
, and you can read about the help I got here.
Good luck!
