The AMB (Kress) 1050 FME-U DI alternative uses ER-16 collets and is available in a 110V version according to the manual. It shouldn’t draw more than 11A, so you shouldn’t need a separate circuit for it (if you can find one) or a 230V step-up transformer.
Unlike the standard types, apparently there’s no info on runout for either type.
OOPs Damen CNC says the Mafell’s “Concentricity of <0,10mm at a distance of 25mm”. Mafell claims to be 6 dBA quieter than the Kress (10 dB quieter would seem half as loud).
