So I can submit my next post please.
Thank you.
Thank you.
Can you post the info on what you have the speeds, feed, and depth of cut you are set at?
I use carbide drills made for circuit boards, run them at 12K RPM, 0.10" peck (I am probably going to change it to 0.15", but for now, I still have gcode that is 0.10" peck) and 30IPM plunge. I can make 5 or so 4 player boards (533 holes each board) before needing to change the bit.
Could you post in this thread below so I can post my next tutorial?
Curious why you can’t just make another post, without someone else posting first??
The site has a limit of 3 consecutive posts by the same user to prevent spamming threads. So someone needs to post in the thread so I can continue with my tutorial.
I could make a new thread, but it then becomes a pain locating all of the different threads to get through the process.
I have upgraded you to a Regular, so you should be able to post — if that doesn’t work, let us know.
Thank you, will.
I will find out when I get home from work today.
