Can you please recommend a machine strategy to avoid having a final piece looking as if I glued 2 pieces together? (Please see image below)
Software I am using is VCarve Desktop.
The process I followed using a #201 bit in my Shapeoko Pro:
a. I performed 3 profile passes from the top, each with a depth of 0.32"
b. I flipped the stock (using dowel pins)
c. I performed 3 profile passes from the back, each with a depth of 0.32"
Note: The reason I performed ‘incremental’ profile passes is to avoid the machine losing steps due to the generated torque (the stock is 1.80" thick, which seems to be excessive to handle by the Shapeoko).
Is there something I should do to avoid the issue described above?
Is there an Z- Axis extension / device I can buy in order to enable using longer router bits? Maybe this would help me to perform the profile tool only from one side and avoid the issue?
You are cutting far deeper than the 0.75" cutting flute length — I would suggest sourcing a long reach endmill w/ a flute length better suited to this and leaving a roughing clearance and taking a finishing pass.
leaving a roughing clearance on one side greater than the mis-alignment you are seeing
once you’ve roughly cut things to size on the flip side (again, leaving the same roughing clearance, make a fully depth finishing pass which starts at twice the roughing clearance from the finished size and spirals in
What about doing the profile cut from one side only?
I imagine I would need a longer bit. Would this require to raise the router? How much is adequate to raise while avoiding a malfunction and/or safety hazard?
William,
It seems that the only way to raise the router is by taking off the ‘dust cullection-shoe’ assembly off; as such device is too thick.
Is there another dust collection device -but slimmer? so I can still have dust colleciton?
Folks have worked up a variety of other dust collection options (and I spent a lot of time trying myself), but the Sweepy hits the sweet spot of simplicity, reliability and low-cost — can’t really suggest anything else, and unfortunately, the Sweepy Pro only works on the HDM and forth-coming 5 Pro.
