I am having trouble with pocketing a hole. I am trying to make it 56.5mm x 56mm. The hole is only coming out to be 49.8 mm x 55.45 mm. The depth is ok so I am not worried about it.
I am using an IDC 1/4 Compression bit. Designed in Carbide create pro and ran through Gsender on a longmill MK2.
Included are the files. I first cut a pocket, then when that was too small I thought perhaps I needed to contour the inside. Still no luck.
