I’m going to be daring and not sign my “built by” plate with the sharpe. Once I get proficient in the use of this machine I plan on engraving it!
Great idea! I have been 3D printing for years. Wanted to try my hand at “subtractive modeling” lol. Very intrigued!
if you come from the 3D printing world… one can cut STL files on a CNC as well, just subtractive… it might at least give you some familiar start
(see Cutting STL models with Carbide Create Pro (nearly-2021 edition) )
C3D will send you the new cable.
In the meantime, if you had access to some parts, you could just ignore one wire and add your own connectors (looks like a Molex minifit jr maybe on the Z switch…got a pic of the board?).
Doesn’t have to make it to the board, the circuit is in 2 pieces. It connect at the minute switch near the z axis. Then travels the z and connects there to another wire that goes to the board. So one 3 pin male and one 3 pin female would do it. They would have to be the exact connector used on the existing though, or I would wind up having to re-wire in 4 places instead of 2
Yup. Like I said, IF you had connectors on hand.
C3D will get you a replacement faster than anywhere else anyway.
