Probing issue with bit zero v1
I am having an issue with the bitzero prob deal. I have v1, and when I place on corner of the piece and it does the z first, then it does the z again crashing into the bitzero.
I did just do a test with the v2 selected and touched the bit with a piece of metal and it went 4 ways then moved more toward the center and did the z last.
Then did the test on the v1 and it did the z first, I touched it before the timeout and then it raised and lowered straight down again until it errored out.
Any suggestions?
3xxl, z plus, CM640
I had a z crash with a V1 BitZero and an earlier version of Carbide Motion. Try the new CM 649
Thank You, What can it hurt right! I will download and give it a whirl.
No change. still doing the same thing.
Just for the heck of it, reboot your PC and see if that makes a difference
I wrote up a bit on this at:
Post screengrabs and let us know step-by-step what you are doing/expecting?
