Is there 0.5" above the surface of your stock?
Do you have the Zero Height set in your file at the Bottom to match where you are physically setting things?
Is your machine mechanically sound? Are all the wiring extensions and connectors in good shape? Did the machine make an odd sound or fail to lift at any point when it should have?
I would suggest working up a very basic calibration file such as:
