I’ve been working with my shapeoko more than some weeks now, got quite familiar with the machine.
Now I can’t get it to run anymore. I was putting a V-bit for an important project that needs to be finished first week of January and all of the sudden the router fell down (as if it had no more power). Luckily, not injured.
My computer can’t connect to the cutter anymore, so I tried switching off the shapeoko and putting it on, alas no solution.
I opened the protection cap of the board and I think there should be blue lights flashing?
When I put the switch of my power supply on, there is a short flash of blue lights together with the motors starting up, but only very short (less than one second), and everything dies again.
Could there be some help? I hope my board isn’t fried, cause this project is important
Yes, the light of the supply itself is on, but it’s as if the board doesn’t want to get the power. If I put on and off the switch, the board has brief lights and dies out within one second…
Maybe try to unplug the stepper motors from the controller and see if the power still fades instantly ?
In any case get in touch with support@carbide3d.com about this problem
Yes, I’ve sent a mail to this adress, but have no response. I’ve already sent a mail once, which was never answered. That’s why I threw this case on here
I had something similar once and it was the rocker switch being bad. If you are good with soldering and understand electronics you could try replacing it. Or even desoldering it and checking with a meter. Fixed up my power supply
