I am pretty new to this, been doing it about a months. I have figured out all the normal things, like pockets and contours. But the part I am working on now need a large “countersink” inside of an aluminum disk. The disk measures about 4" wide, with a 1.75" hole, and is about 1/2" thick. I need to mill a countersink in the holes, all the way around. I am trying to learn meshcam, since I figured this is the type of cut it is for.
Not sure it applies to your need but here’s a recent discussion on using contour toolpaths to do chamfers
(that thread was about wood though)
I don’t think you need 3D toolpaths “just” for countersinking a set of holes, chances are a set of 2D circular contours with appropriate stepdown should work. What tool are you going to use ?
Sorry, I don’t. I would recommend learning to model in Fusion before trying to do anything in the CAM side of Fusion.
For reference, here is my order of operations for a countersink:
Bore the hole using the appropriate square endmill
Rough bore the countersink using the same square endmill
Bore the countersink using the appropriate size ball endmill
The tool Neil suggested would also work. I just tend to use the tools I already have on hand unless I am trying to do a lot of something that would benefit from buying a new tool.
As Nick says, there’s quite a steep learning curve to Fusion.
If you want to spend the time, Lars Christensen has excellent introductory videos on YT and NYCCNC have very good specific ‘how to do this thing’ content once you have the basics down.
Or just continue to use Solidworks. You can use a CAM add in, like SolidWorks Cam, HSM Works, MasterCam ect. Or, you can import your model into Fusion360, which essentially includes HSM Works, to program machine operations. Fusion360 is a handy piece of kit, and the default integration of cam is quite convenient. I think most would agree, SW is better.
They are not cheap. You mentioned you used it at work, so I wasn’t sure what kind of access you might have to a seat.
If its just for hobby/fun, I’d recommend designing in SW, then importing into Fusion360 for CAM. The hobby license will essentially give you HSM Works for zero dollars. I kept my personal use account, and still use it for 3D printing projects and various non work related junk. You can most certainly import STEP files, as well as another 11 or 12 file types.
I prefer SolidWorks, but use Fusion360 because paid seat is CHEAP. And its perfectly acceptable for the things I do daily. The cloud aspect is of no benefit to me, and is a bit of an annoyance on rare occasions. But, its cheap. Having integrated CAM is great.
