WillAdams
(William Adams (Carbide 3D))
4
set up a file:
Set Background
Load Image
Adjust as necessary:
Draw a line of the requisite length:
then rotate it:
and adjust as need be:
then draw the outline:
then measure to get the rotation:
Done
then rotate to flat:
then clean up:
Then draw a ball-nose tool up in profile:
Done
and
position relative to the desired slope:
and at the bottom:
then use the technique from:
to draw a suitable number of offset lines and assign No Offset Contour toolpaths to the requisite depths.
