I have looked around but have not found the answer. Sorry if I am just missing it. How many computers can you install carbide create pro on? I have a main computer that I use for designing but the computer I have connected to my cnc is more than capable of running the software as well. It would be nice to be able to open and make tweaks without having to go back into the house.
One may install Carbide Create Pro on as many computers as one wishes per the license — so long as only one copy is in use at any given time.
Awesome thanks for letting me know.
Just be aware the “working” folders will not be shared - unless you set it up that way.
Also, if you design a project with text on the primary computer, you won’t see the same font on the secondary computer if the font isn’t installed on both machines. It should cut as expected if you use CM, but that may not be the case if you’ve edited the project on the secondary machine and saved it.
Thanks for letting me know, I have a nas set up that I use fir any files that I make for my cnc or lasers. I would have completely forgotten about the text thing. I have a large folder of texts somewhere that I usually install on my computers but have not on my new cnc computer that could have been a pain.
the other thing to synchronize is the tool library, thats just a CSV file in the data folder of CC so not too hard to sync
