Hi @Miguel,
Definitely get a tapered bit, they are awesome for 3D carving.
I recently did a 3D project with CC Pro and a tapered endmill, it’s here if you need details.
This thing is, Carbide Create does not support tapered endmill geometry, but don’t let that stop you: in practice, declaring the bit as a small ballnose will work out just fine in the majority of cases. In that thread I referenced, I declared the tapered endmill as “1/32th ballnose”, because the radius of the tip of my tapered endmill was roughly 1/32". The preview in CC may not match reality in that situation, but it’s a minor inconvenience.
EDIT: sorry, I misread and you are using VCarve Pro, not CC Pro. I’m not quite sure whether VCarve models tapered endmill, someone here probably knows.
