Might be user error?
If I try to recreate it in a test file it doesn’t happen again, only in my project file
Wondering if anyone else has encountered this issue?
Image 1) 1/8" End mill tool path
Image 2) 1/16" End mill tool path
Image 3) test trying to recreate the problem in a new file - but it works perfectly
WillAdams
(William Adams (Carbide 3D))
2
Post the file which has this problem?
Tod1d
(Tod (with 1 'd'))
3
Did you have the “Previous Diameter” set to 0.250, instead of 0.125?
Unfortunately it’s a top secret, classified project
I’ll try to strip down the file to just isolate the issue.
Unfortunately not
Tod1d
(Tod (with 1 'd'))
6
Ah, yes! We ran into this recently. It’s a bug. But if you change the Previous Diameter to 0.0625, it works. ???
Yes! That works perfectly. Thanks!
Any idea what I can avoid doing to trigger the bug? Or as general practice should I use the lower previous diameter?
system
(system)
Closed
8
