S3 XXL Pro and Regular.... Can they Double Team a Long Piece of Stock
I know where you mind is going, but lets keep things PG here.
Serious question though if I had a legitimate production reason to have an XXL and an XXL Pro go at a piece of stock at the same time what where one machine 1/2 while the other machined the other half…
Things I’d like to know X direction “throat” clearance and “travel”… meaning is there any difference between how much either machine can fit along their X axises and how far they can travel on them.
Y- “reach” does one machine have slightly more reach than the other so that Y- impacts could be avoided if not using boundaries.
Bed height… is there enough adjustment in the feet on these machines to bring the beds on the same Z plane or would each require its own custom table of independent height to make them sit on the same plane?
This is a pretty interesting exercise. I just hope they don’t come in at the same time for a tool change.
If you intend the piece to be a “seamless” project, you would have to be EXTREMLY careful that the toolpaths do not occupy the same space at the same time. In that case you would literally have both spindles or other parts collide.
I would look into the tiling function that some software packages provide.
Try this wiki: https://wiki.shapeoko.com/index.php/Fabrication_Techniques_%26_Hardware#Tiling
Oh absolutely, but the video of it working would be worth the difficulty,
A video of dancing spindles would be very interesting if you could video both at the same time.
