Separating parts in a file
I am pulling a cut file out of droobox to cut on my machine. There is multiple parts in the file. What is the easiest way to take one of the parts and make a separate file to cut just one part? I want to mae a cut file for each part individually.
Duplicate the file once for each part, naming the duplicates as desired for the parts you wish to cut.
Open each and in turn, delete all but the geometry and Toolpaths needed for the part for each file.
Makes sense. Thank you. One more quuck questiion. To do a keyhole slot, can i just sraw a polyline for the desired length, click at that point and then follow the sMe line back to the starting point and click that point again?
Yes, that works, we discussed this here:
