Setting up a file for a branding iron
As requested on support…
If one purchases a rectangular branding iron from:
we have a video on this sort of thing courtesy @wmoy at:
and also see the relevant Material Monday videos for more on feeds and speeds:
Then one would set it up as:
and set up the design:
and then, if one wants the type raised, draw in a rectangle to remove the background:
and add dog bones at the corners:
Since this is a brand, don’t forget to mirror the text:
Then select the background and the design elements which one wants to be raised:
and assign a suitable toolpath, perhaps something along the lines of:
which previews as:
Check feeds and speeds, do test cuts, &c.
Ok, I will ask. Why the dogbones?
Without, the round endmill won’t reach all the way into the corners. You’d be left with raised material.
You could also make the outer rectangle a bit bigger - 1/2 the width of the bit on each side would do it - actually I think the overlap needed is a lot less than 1/2 the width, I don’t want to do the math though.
Duh, Pull your head out of your arm pit Zman.
I was visualizing a pocket overlapping the part. Time once again to turn on the brain.
Thanks
