david5
(David Mattice)
August 26, 2024, 11:58pm
1
Using CC build 778 what settings should I use for : plug depth (D)
Top gap (S)
Should these settings be zero? Or what is recommended
Previous version said Glue gap
WillAdams
(William Adams (Carbide 3D))
August 27, 2024, 12:24am
2
There are some sample files and parameters at:
We just posted an update to Carbide Create with a rework of the inlay mode. This is a fundamentally different take on how to make inlays, so inlay toolpaths created with the old code will be reset back to a basic Advanced V-carve in this build. You’ll need to reenable the inlay mode and set the new parameters.
You can grab 777 here: Download Carbide Create V7
Here are a few of the test pieces we’ve done with bamboo and walnut (with zero special effort spent in setup or machining):
[before…
system
(system)
Closed
September 25, 2024, 11:58pm
3
