If the unit won’t move forward enough with the correct configuration, the most likely culprit is insufficient Y-axis belt tension — are your belts tensioned per the instructions?
Alternately, you could defer the BitSetter configuration until after you have calibrated for belt stretch — that should then allow this to work.
For that see:
Or, contact support, which is probably the best option.
