I have a Shapeoko xxl. Running carbide motion v5 on my MacBook Pro. When I do the initial startup, it moves forward, stops for bit insertion, when I click for the bitsetter measurement, the bit moves over to the center of the bitsetter ( older model, v1?), then moves down the z axis 1 inch and freezes. I get a “probing cycle failed” message.
I don’t see anything mechanical, Z moves freely when power is off.
Tried multiple restarts.
Reloaded with fresh v5 motion driver.
Still freeze probe cycle failure. Exactly the same each time.
I am out of ideas.
Please advise.
Chris
Which Shapeoko do you have? 3, 4 or Pro?
Which Z-axis does your machine have? Belt-drive, Z-Plus, HDZ?
Have you configured the machine to have the correct Z-axis?
Do you have a BitZero? Where is it? Where is the ground lead? Are they touching?
Let us know at support@carbide3d.com
I have an xxl purchased in 2019. Not a pro.
It has the z-plus screw drive.
I have the bit zero (older version) at front left.
It works fine
Bit setter is at feont right corner.
Don’t know what you mean to “configure correct z axis”.
See:
Let us know at support@carbide3d.com and we will do our best to assist.
Went through the load defaults as advised.
It’s fixed!
Thanks for that!
Chris
Check your BitZero magnet. If it is touching ground or the BitZero you will get a BitSetter error.
