robgrz
(Rob Grzesek (Carbide 3D))
122
That was the workflow we intended so we tried to make it simple to enable/disable the BitSetter if you has a job that wasn’t suitable for BitSetter.
One thing to note, if you turn the BitSetter on/off, be sure to reset your zero because all of the internal references will change.
Rob, just to be clear, if we remove the tick box to disable the BitSetter, do we need to send the config to the Shapeoko or is everything within CM?
SDDavinci
(Jeremy P Gadbaw)
124
Not sure if you’re using CC or not.
I just save my flycut as a non TC gcode.
robgrz
Closed
125
