Not even a teaser pic, slightly blurry and taken from a distance??? 🥸
Give the 🦫 fanclub something
I probably shouldn’t… but it does look good on the pro…
Haha, nice try Vince!!
It’s an HDZ v3.0/3.2 on an adapter plate, I’ll give You that.
Thank you so much for the update Luke! Can’t wait to order.
After my 1.5kw 65mm spindle gave out, my machine has been sitting waiting on the ability to utilize an 80mm mount (without custom fabrication, don’t have the ability atm).
Will the new HDZ support both 65mm and 80mm?
I would assume that the HD spindle mounts already in the Carbide shop HD section will fit.
Ooof I hope the new one has whatever “EZ-Tram” entails. Tramming the SO Pro was not fun. Key to chasing that floor finish on aluminum.
Thats a HDZ 1.0 on a pro
As always!
I stand corrected.
It is a nice preview of what is to come for the Pro owners.
Anything new to report on the status of the HD Anything new to report on the status of the HDZ pro?
Machined parts are being made. We hope to be building the first batch in a couple of weeks.
Sounds great! We will not hold you exactly to that date Luke! But, thanks for the update!
Thanks Luke. Are you able to share the dimensions of the HDZ pro?
It’s as wide as the existing Z, travel is 150mm
Do you know what the Height?
On a pro or 4? Where do you want me to measure from?
What is the height on the Pro as measured from the top of the X axis to the top of the HDZ Pro.
I just checked and it’s approx 28cm from the top of the pro’s X axis
Does the new HDZ Pro have tramming adjustments like the older one?
