Hi guys,
I’m definitely still considered new at this
I’m running a shapeoko 3 XXL with CC and CM
Everything has been fine I bought it used when I first installed the program the machine would run its course and then it would just stop right where it ended the job.
I would shut the router off and then send it home.
I recently moved obviously unplugged everything and have been using it again, when the job finishes the machine takes off to the back right corner home and it’s really hard for me to lean all the way over and shut the router off.
Is there any way to program this so when the job is complete the unit does not move anywhere unless I manually click home? I’m not sure why the settings changed from unplugging and moving locations but I can’t seem to find the answer on topics or on Google
