I updated to CM 613. I went through the somewhat cumbersome setup process (because it was setup just fine prior). Initialization and measuring the tool was done as per instructions. Then I jogged the Y forward and it rammed in the metal end plates. Expected (prior) behaviour would have been for it to stop at the max distance as given in the settings. Looking at the config file as show in the software I noticed the travel distance is given as 871mm. However, in reality it is much closer to 856mm (with about a 1mm gap to the metal end plate.
In previous versions this value was easy to change, but the option has been removed in 613. ![]()
I had a look around the Windows directories, but I could not find the file where to change these settings. Any pointers would be appreciated.
There appear to be two places in the settings file, where XYZ max travel distances are defined, and they do not correspond to each other.
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 613
Machine Controller State: INIT
Grbl Cycle: Idle
"bitRunnerEnabled": false,
"bitSetterEnabled": true,
"bitSetterX": -5.5,
"bitSetterY": -854.5,
"bitZeroType": 2,
"connection": 1,
"lastConfigSent": 3,
"lastProbeIndex": 0,
"lastSizeOption": 0,
"odometer": [
"cleared": false,
"minutes": 2.2786166666666676,
"startDate": "2023-07-12",
"travelX": 2215.550003528595,
"travelY": 5056.850088581443,
"travelZ": 717.2700042724609
"showCarbideRouterRpm": true,
"spindleType": 0,
"travelX": -865.0,
"travelY": -871.0,
"travelZ": -95.0,
"version": 0,
"workOffsetX": 0.0,
"workOffsetY": 0.0,
"workOffsetZ": -0.08499999999999375
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 5, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 200, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 1000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 270, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 95, Z Max travel, millimeters
Maintenance:
Travel (km) 0.00, 0.01, 0.00, 0.04 Hours since 2023-07-12
Queue Empty
