Shapeoko Pro XXL X Axis accuracy
Hi everyone,
I have gone through a few of the posts about calibration and setting up everything. However I do not have a very good grasp on the best approach to solve the following:
My machine is cutting almost exactly the measurement inputted on carbide create in the Y direction but is a 1/16 of an inch off consistently in the X direction. Is there some posts that can be recommended to help solve this? I know there is a ton of information on here but I can’t seem to figure out the right approach to solving this.
See:
Is the first link embedded important or would other posts on belt stretch be sufficient? I ask only because that link is not working for me.
Thank you for the help!
The first link just went into the specifics of interacting with the MDI and doing the calculations — the balance of the post should obviate it, if not, ask and we’ll try to make things clear.
I was able to do the math and got it corrected, I did get a little tripped up when I just put the ratio value of 0.998 instead of 39.998 but after that correction everything is working great.
Thank you!
