Hi i was doing signs today and i went to do another and it was above the work peace. I used the bit zero and that did not work so i manually zeroed it. And i am still getting the same problem does anyone have any ideas? In carbide create i have checked multiple times to make sure it is the write thickness. I cant figure out why this keeps happening? Thanks in advanced.
Is your Z zero in Create set to be at the bottom rather than the top of the workpiece?
It is set at the top.
Can you share your gcode?
(Design File: C.Projects.Gordon.Cutting.Boards.Files.Justlogo.V0.1.c2d)
(stockMin:0.000in, 0.000in, -1.490in)
(stockMax:16.000in, 11.000in, 0.000in)
(STOCK/BLOCK,16.000, 11.000, 1.490,0.000, 0.000, 1.490)
G90
G20
(Move to safe Z to avoid workholding)
G53G0Z-0.197
(VCarve.Toolpath.3.-.Vee)
M05
(TOOL/MILL,0.001, 0.000, 0.394, 30.00)
M6T302
M03S18000
(PREPOSITION FOR RAPID PLUNGE)
G0X12.8101Y1.6133
Z0.5000
G1Z0.0000F12.0
X12.8159Y1.6172Z-0.0079F35.0
X12.8258Y1.6166Z-0.0099
X12.8305Y1.6157Z-0.0119
X12.8354Y1.6143Z-0.0149
X12.8440Y1.6102Z-0.0228
X12.8548Y1.6023Z-0.0377
X12.8539Y1.5948Z-0.0361
X12.8524Y1.5867Z-0.0356
X12.8265Y1.4743Z-0.0357
X12.8233Y1.4569Z-0.0360
X12.8232Y1.4495Z-0.0365
X12.8243Y1.4468Z-0.0349
X12.8266Y1.4439Z-0.0321
X12.8323Y1.4392Z-0.0256
X12.8393Y1.4358Z-0.0195
X12.8477Y1.4341Z-0.0145
X12.8566Y1.4347Z-0.0107
X12.8628Y1.4358Z-0.0089
X12.8691Y1.4376Z-0.0082
X12.8759Y1.4449Z0.0000
Z0.5000
G0X12.8793Y1.6231
G1Z-0.0043F12.0
X12.8548Y1.6023Z-0.0377F35.0
Z0.5000
G0X12.7156Y1.6133
G1Z0.0000F12.0
X12.7214Y1.6172Z-0.0079F35.0
X12.7313Y1.6166Z-0.0099
X12.7359Y1.6157Z-0.0119
X12.7409Y1.6143Z-0.0148
X12.7461Y1.6121Z-0.0192
X12.7497Y1.6101Z-0.0230
X12.7603Y1.6023Z-0.0377
X12.7594Y1.5948Z-0.0361
X12.7581Y1.5879Z-0.0357
X12.7320Y1.4744
X12.7287Y1.4569Z-0.0360
Y1.4495Z-0.0365
X12.7298Y1.4468Z-0.0349
X12.7320Y1.4439Z-0.0321
X12.7378Y1.4392Z-0.0256
X12.7447Y1.4359Z-0.0196
X12.7482Y1.4348Z-0.0172
X12.7532Y1.4341Z-0.0145
X12.7609Y1.4345Z-0.0111
X12.7673Y1.4356Z-0.0091
X12.7746Y1.4376Z-0.0082
X12.7814Y1.4449Z0.0000
Z0.5000
G0X12.7848Y1.6231
G1Z-0.0043F12.0
X12.7603Y1.6023Z-0.0377F35.0
Z0.5000
G0X12.6776Y1.5571
G1Z-0.0043F12.0
X12.6523Y1.5310Z-0.0372F35.0
X12.6512Y1.5229Z-0.0359
X12.6405Y1.4752Z-0.0357
X12.6380Y1.4631Z-0.0361
X12.6363Y1.4515Z-0.0377
X12.6215Y1.4506Z-0.0156
X12.6147Y1.4489Z-0.0096
X12.6120Y1.4474Z-0.0089
X12.6095Y1.4455Z-0.0088
X12.6043Y1.4420Z-0.0095
X12.6006Y1.4399Z-0.0106
X12.5951Y1.4380Z-0.0122
X12.5888Y1.4366Z-0.0147
X12.5830Y1.4361Z-0.0175
X12.5759Y1.4367Z-0.0211
X12.5685Y1.4392Z-0.0255
X12.5625Y1.4424Z-0.0298
X12.5572Y1.4469Z-0.0340
X12.5531Y1.4528Z-0.0370
X12.5513Y1.4575Z-0.0381
X12.5498Y1.4644Z-0.0389
X12.5493Y1.4705Z-0.0392
X12.5498Y1.4846Z-0.0390
X12.5520Y1.4971Z-0.0373
X12.5569Y1.5114Z-0.0343
X12.5628Y1.5225Z-0.0309
X12.5721Y1.5348Z-0.0255
X12.5833Y1.5445Z-0.0196
X12.5941Y1.5504Z-0.0147
X12.6030Y1.5530Z-0.0118
X12.6084Y1.5535Z-0.0107
X12.6137Y1.5534Z-0.0102
X12.6187Y1.5527Z-0.0099
X12.6235Y1.5512Z-0.0100
X12.6272Y1.5495Z-0.0105
X12.6311Y1.5468Z-0.0115
X12.6361Y1.5420Z-0.0139
X12.6407Y1.5387Z-0.0194
Z0.5000
G0X12.6363Y1.4515
G1Z-0.0377F12.0
X12.6381Y1.4470Z-0.0357F35.0
X12.6422Y1.4422Z-0.0304
X12.6491Y1.4376Z-0.0229
X12.6576Y1.4347Z-0.0163
X12.6645Y1.4344Z-0.0123
X12.6697Y1.4350Z-0.0102
X12.6752Y1.4360Z-0.0086
X12.6802Y1.4375Z-0.0080
X12.6869Y1.4449Z0.0000
Z0.5000
G0X13.0101Y1.4695
G1Z0.0000F12.0
X13.0108Y1.4604Z-0.0112F35.0
X13.0017Y1.4512Z-0.0116
X12.9925Y1.4446Z-0.0123
X12.9824Y1.4396Z-0.0135
X12.9716Y1.4365Z-0.0155
X12.9573Y1.4349Z-0.0177
X12.9492Y1.4356Z-0.0193
X12.9402Y1.4378Z-0.0223
X12.9328Y1.4412Z-0.0257
X12.9255Y1.4462Z-0.0300
X12.9217Y1.4497Z-0.0324
X12.9172Y1.4558Z-0.0358
X12.9132Y1.4648Z-0.0385
X12.9117Y1.4710Z-0.0392
X12.9109Y1.4795
Y1.4840Z-0.0391
X12.9117Y1.4886Z-0.0394
X12.9120Y1.4946Z-0.0378
X12.9147Y1.5055Z-0.0355
X12.9188Y1.5155Z-0.0323
X12.9237Y1.5241Z-0.0287
X12.9311Y1.5337Z-0.0236
X12.9419Y1.5436Z-0.0171
X12.9492Y1.5484Z-0.0135
X12.9552Y1.5512Z-0.0114
X12.9613Y1.5529Z-0.0103
X12.9668Y1.5535
X12.9751Y1.5528Z-0.0120
X12.9838Y1.5501Z-0.0164
X12.9904Y1.5464Z-0.0216
X12.9957Y1.5422Z-0.0269
X12.9994Y1.5383Z-0.0314
X13.0020Y1.5348Z-0.0344
X13.0029Y1.5325Z-0.0358
X13.0066Y1.5334Z-0.0293
Z0.5000
G0X13.0029Y1.5325
G1Z-0.0356F12.0
X13.0030Y1.5274Z-0.0353F35.0
X13.0012Y1.5211Z-0.0325
X12.9956Y1.5120Z-0.0258
X12.9896Y1.5057Z-0.0206
X12.9844Y1.5017Z-0.0171
X12.9768Y1.4977Z-0.0138
X12.9683Y1.4943Z-0.0118
X12.9594Y1.4917Z-0.0109
X12.9496Y1.4900Z-0.0106
X12.9327Y1.4880Z-0.0108
Z0.5000
G0X13.0197Y1.4614
G1Z0.0000F12.0
Z0.5000
G0X13.0361Y1.5394
G1Z0.0000F12.0
X13.0426Y1.5468Z-0.0079F35.0
X13.0506Y1.5489Z-0.0094
X13.0574Y1.5496Z-0.0120
X13.0632Y1.5494Z-0.0155
X13.0705Y1.5472Z-0.0214
X13.0761Y1.5441Z-0.0272
X13.0815Y1.5391Z-0.0338
X13.0831Y1.5357Z-0.0356
X13.0835Y1.5312Z-0.0362
X13.0821Y1.5174Z-0.0359
X13.0729Y1.4772Z-0.0354
X13.0701Y1.4611Z-0.0365
X13.0698Y1.4566Z-0.0366
X13.0703Y1.4504Z-0.0370
X13.0717Y1.4471Z-0.0360
X13.0730Y1.4454Z-0.0348
X13.0727Y1.4447Z-0.0335
Z0.5000
G0X13.0730Y1.4454
G1Z-0.0348F12.0
X13.0793Y1.4408Z-0.0285F35.0
X13.0870Y1.4376Z-0.0222
X13.0921Y1.4365Z-0.0191
X13.1007Y1.4364Z-0.0151
X13.1093Y1.4382Z-0.0121
X13.1153Y1.4408Z-0.0105
X13.1246Y1.4463Z-0.0087
X13.1326Y1.4522Z-0.0077
X13.1361Y1.4539Z-0.0092
X13.1398Y1.4547Z-0.0124
X13.1464Y1.4545Z-0.0207
X13.1567Y1.4531Z-0.0366
Z0.5000
G0X13.1719Y1.5381
G1Z-0.0358F12.0
X13.1544Y1.5581Z0.0000F35.0
Z0.5000
G0X13.0815Y1.5389
G1Z-0.0340F12.0
X13.0817Y1.5393Z-0.0334F35.0
Z0.5000
G0X13.0549Y1.3975
G1Z-0.0317F12.0
X13.0552Y1.3970Z-0.0327F35.0
X13.0550Z-0.0323
Z0.5000
G0X13.0561Y1.3963
G1Z-0.0342F12.0
X13.0586Y1.3952Z-0.0348F35.0
X13.0614Y1.3937Z-0.0341
X13.0655Y1.3912Z-0.0319
X13.0740Y1.3859Z-0.0247
X13.0841Y1.3794Z-0.0144
X13.0903Y1.3771Z-0.0107
X13.0932Y1.3773
X13.1026Y1.3792Z-0.0123
X13.1095Y1.3817Z-0.0142
X13.1155Y1.3845Z-0.0163
X13.1243Y1.3904Z-0.0204
X13.1301Y1.3956Z-0.0233
X13.1359Y1.4019Z-0.0263
X13.1414Y1.4095Z-0.0291
X13.1467Y1.4189Z-0.0317
X13.1504Y1.4272Z-0.0333
X13.1535Y1.4363Z-0.0345
X13.1563Y1.4471Z-0.0352
X13.1583Y1.4595Z-0.0358
X13.1719Y1.5381Z-0.0359
X13.1933Y1.5569Z-0.0051
Z0.5000
G0X13.0533Y1.3975
G1Z-0.0295F12.0
X13.0550Y1.3970Z-0.0323F35.0
X13.0546Y1.3973Z-0.0316
Z0.5000
G0X13.0548Y1.3956
G1Z-0.0318F12.0
X13.0561Y1.3963Z-0.0342F35.0
Z0.5000
G0X13.0073Y1.9067
G1Z0.0000F12.0
X13.0284Y1.8922Z-0.0339F35.0
X13.0107Y1.8724Z0.0000
Z0.5000
G0X13.2220Y1.9783
G1Z-0.0800F12.0
X13.2550Y1.9465F35.0
X13.2722Y1.9324
X13.2829Y1.9252
X13.2923Y1.9197Z-0.0789
X13.3034Y1.9144Z-0.0698
X13.3092Y1.9121Z-0.0659
X13.3183Y1.9091Z-0.0607
X13.3330Y1.9057Z-0.0550
X13.4266Y1.8919Z-0.0334
X13.4450Y1.9067Z0.0000
Z0.5000
G0X13.2220Y1.9783
G1Z-0.1000F12.0
X13.2722Y1.9324
X13.2829Y1.9252Z-0.0883
Z0.5000
G0X13.4471Y1.8724
G1Z0.0000F12.0
X13.4266Y1.8919Z-0.0333F35.0
Z0.5000
G0X13.5596Y2.2257
G1Z-0.0443F12.0
X13.5404Y2.1983Z0.0000F35.0
Z0.5000
G0X13.5352Y2.3489
G1Z-0.0800F12.0
X13.5404Y2.3373Z-0.0748F35.0
X13.5433Y2.3290Z-0.0699
X13.5474Y2.3136Z-0.0632
X13.5510Y2.2881Z-0.0573
X13.5596Y2.2257Z-0.0443
X13.5857Y2.2024Z0.0000
Z0.5000
G0X13.5352Y2.3489
G1Z-0.0837F12.0
Z0.5000
G0X13.5600Y2.4717
G1Z-0.0436F12.0
X13.5404Y2.4960Z0.0000F35.0
Z0.5000
G0X13.6516Y2.6215
G1Z-0.0403F12.0
X13.6714Y2.6009Z0.0000F35.0
Z0.5000
G0X13.7057Y2.8271
G1Z-0.0134F12.0
X13.6459Y2.7768Z-0.0800F35.0
Z0.5000
G0X13.7057Y2.8271
G1Z-0.0134F12.0
X13.6459Y2.7768Z-0.0993F35.0
Z0.5000
G0X13.2216Y2.7288
G1Z-0.0800F12.0
X13.2637Y2.7704F35.0
X13.2724Y2.7775
X13.2811Y2.7835
X13.2899Y2.7885Z-0.0758
X13.2987Y2.7923Z-0.0692
X13.3074Y2.7950Z-0.0645
X13.3162Y2.7967Z-0.0616
X13.3250Y2.7972Z-0.0606
X13.4648Y2.7973Z-0.0608
X13.5904Y2.7978Z-0.0616
X13.6042Y2.7966Z-0.0641
X13.6181Y2.7926Z-0.0712
X13.6319Y2.7861Z-0.0800
X13.6459Y2.7768
X13.6516Y2.6215Z-0.0403
X13.6344Y2.5955Z0.0000
Z0.5000
G0X13.2216Y2.7288
G1Z-0.1000F12.0
X13.2724Y2.7775Z-0.0948
X13.2811Y2.7835Z-0.0844
X13.6319Y2.7861Z-0.0828
Z0.5000
G0X13.2246Y2.3492
G1Z-0.0800F12.0
X13.3250Z-0.0570F35.0
X13.4136Z-0.0574
X13.4970Y2.3493Z-0.0598
X13.5064Y2.3492Z-0.0623
X13.5148Y2.3490Z-0.0666
X13.5267Y2.3489Z-0.0754
X13.5352Z-0.0800
X13.5394Y2.3578Z-0.0767
X13.5431Y2.3671Z-0.0705
X13.5457Y2.3757Z-0.0660
X13.5476Y2.3838Z-0.0628
X13.5516Y2.4113Z-0.0563
X13.5600Y2.4717Z-0.0436
X13.5857Y2.4981Z0.0000
Z0.5000
G0X13.2246Y2.3492
G1Z-0.1000F12.0
X13.4136Z-0.0574
X13.5352Z-0.0838
Z0.5000
G0X13.0281Y2.8148
G1Z-0.0339F12.0
X13.1098Y2.8023Z-0.0526F35.0
X13.1197Y2.8004Z-0.0559
X13.1337Y2.7961Z-0.0630
X13.1448Y2.7914Z-0.0711
X13.1535Y2.7868Z-0.0790
X13.1691Y2.7766Z-0.0800
X13.1828Y2.7657
X13.1977Y2.7522
X13.2216Y2.7288
X13.2220Y2.3821
X13.2227Y2.3656
X13.2246Y2.3492
X13.2227Y2.3327
X13.2220Y2.3162
Y1.9783
X13.1899Y1.9467
X13.1739Y1.9332
X13.1683Y1.9289
X13.1577Y1.9219
X13.1485Y1.9167Z-0.0738
X13.1378Y1.9118Z-0.0654
X13.1235Y1.9069Z-0.0571
X13.1094Y1.9038Z-0.0519
Z0.5000
G0X13.0281Y2.8148
G1Z-0.0339F12.0
X13.1691Y2.7766Z-0.0964
X13.1828Y2.7657Z-0.1000
X13.1977Y2.7522
X13.2216Y2.7288
X13.2220Y2.3821
X13.2227Y2.3656
X13.2246Y2.3492
X13.2227Y2.3327
X13.2220Y2.3162
Y1.9783
X13.1899Y1.9467
X13.1739Y1.9332
X13.1683Y1.9289Z-0.0949
X13.1577Y1.9219Z-0.0827
Z0.5000
G0X13.0073Y2.8349
G1Z0.0000F12.0
X13.0281Y2.8148Z-0.0339F35.0
X13.0094Y2.7999Z0.0000
Z0.5000
G0X12.4502Y2.7563
G1Z0.0000F12.0
X12.4569Y2.7635Z-0.0080F35.0
X12.4625Y2.7652Z-0.0087
X12.4674Y2.7661Z-0.0100
X12.4739Y2.7667Z-0.0123
X12.4789Y2.7665Z-0.0148
X12.4860Y2.7650Z-0.0200
X12.4906Y2.7628Z-0.0242
X12.4974Y2.7578Z-0.0319
X12.5000Y2.7549Z-0.0353
X12.5009Y2.7528Z-0.0365
X12.5019Y2.7486Z-0.0375
X12.5011Y2.7440Z-0.0364
X12.4998Y2.7363Z-0.0357
X12.4841Y2.6658Z-0.0356
Z0.5000
G0X12.4584Y2.6453
G1Z0.0000F12.0
X12.4841Y2.6658Z-0.0356F35.0
X12.5005Y2.6453Z0.0000
Z0.5000
G0X12.5019Y2.7486
G1Z-0.0375F12.0
X12.5156Y2.7474Z-0.0167F35.0
X12.5195Y2.7473Z-0.0124
X12.5230Y2.7481Z-0.0096
X12.5267Y2.7499Z-0.0080
X12.5354Y2.7559Z-0.0089
X12.5440Y2.7604Z-0.0106
X12.5520Y2.7634Z-0.0126
X12.5609Y2.7647Z-0.0159
X12.5674Y2.7643Z-0.0193
X12.5743Y2.7626Z-0.0241
X12.5801Y2.7598Z-0.0293
X12.5865Y2.7548Z-0.0357
X12.5880Y2.7525Z-0.0370
X12.5888Y2.7486Z-0.0375
X12.5882Y2.7364Z-0.0363
X12.5860Y2.7258Z-0.0354
X12.5780Y2.6951Z-0.0352
X12.5753Y2.6841Z-0.0356
X12.5741Y2.6760Z-0.0359
X12.5738Y2.6691
X12.5747Y2.6646Z-0.0349
X12.5773Y2.6607Z-0.0318
X12.5834Y2.6557Z-0.0250
X12.5890Y2.6529Z-0.0200
X12.5963Y2.6512Z-0.0154
X12.6038Y2.6511Z-0.0119
X12.6107Y2.6521Z-0.0096
X12.6200Y2.6545Z-0.0082
X12.6269Y2.6618Z0.0000
Z0.5000
G0X12.5865Y2.7548
G1Z-0.0359F12.0
X12.5869Y2.7555Z-0.0345F35.0
Z0.5000
G0X12.4150Y2.7264
G1Z-0.0392F12.0
X12.4146Y2.7324Z-0.0383F35.0
X12.4139Y2.7370Z-0.0369
X12.4127Y2.7416Z-0.0351
X12.4109Y2.7459Z-0.0326
X12.4059Y2.7541Z-0.0268
X12.4006Y2.7599Z-0.0217
X12.3917Y2.7661Z-0.0155
X12.3869Y2.7682Z-0.0133
X12.3822Y2.7696Z-0.0118
X12.3741Y2.7706Z-0.0106
X12.3641Y2.7699Z-0.0111
X12.3591Y2.7686Z-0.0120
X12.3518Y2.7660Z-0.0142
X12.3426Y2.7608Z-0.0182
X12.3375Y2.7570Z-0.0210
X12.3270Y2.7465Z-0.0280
X12.3202Y2.7365Z-0.0330
X12.3150Y2.7257Z-0.0367
X12.3125Y2.7187Z-0.0384
X12.3093Y2.7033Z-0.0400
X12.3087Y2.6923Z-0.0393
X12.3090Y2.6868Z-0.0383
X12.3097Y2.6815Z-0.0370
X12.3119Y2.6744Z-0.0338
X12.3142Y2.6696Z-0.0307
X12.3182Y2.6633Z-0.0262
X12.3249Y2.6565Z-0.0201
X12.3298Y2.6530Z-0.0167
X12.3365Y2.6498Z-0.0135
X12.3426Y2.6481Z-0.0117
X12.3500Y2.6474Z-0.0107
X12.3574Y2.6478
X12.3629Y2.6489Z-0.0115
X12.3694Y2.6510Z-0.0132
X12.3743Y2.6533Z-0.0151
X12.3861Y2.6614Z-0.0212
X12.3938Y2.6690Z-0.0261
X12.4013Y2.6789Z-0.0316
X12.4060Y2.6872Z-0.0349
X12.4096Y2.6957Z-0.0374
X12.4133Y2.7092Z-0.0396
X12.4146Y2.7180Z-0.0398
X12.4150Y2.7264Z-0.0392
Z0.5000
G0X12.2397Y2.7524
G1Z-0.0382F12.0
X12.2306Y2.7556Z-0.0240F35.0
X12.2269Y2.7571Z-0.0188
X12.2230Y2.7593Z-0.0143
X12.2184Y2.7628Z-0.0115
X12.2141Y2.7660Z-0.0106
X12.2100Y2.7681Z-0.0101
X12.2053Y2.7695Z-0.0099
X12.2000Y2.7704Z-0.0102
X12.1902Y2.7700Z-0.0116
X12.1804Y2.7674Z-0.0147
X12.1698Y2.7616Z-0.0196
X12.1604Y2.7537Z-0.0245
X12.1522Y2.7439Z-0.0292
X12.1481Y2.7374Z-0.0318
X12.1444Y2.7302Z-0.0339
X12.1385Y2.7138Z-0.0375
X12.1362Y2.6988Z-0.0389
X12.1360Y2.6872Z-0.0392
X12.1363Y2.6819Z-0.0389
X12.1372Y2.6769Z-0.0384
X12.1400Y2.6691Z-0.0368
X12.1424Y2.6654Z-0.0351
X12.1455Y2.6621Z-0.0326
X12.1493Y2.6592Z-0.0297
X12.1577Y2.6550Z-0.0238
X12.1648Y2.6532Z-0.0199
X12.1724Y2.6531Z-0.0161
X12.1800Y2.6543Z-0.0128
X12.1873Y2.6569Z-0.0106
X12.1916Y2.6592Z-0.0096
X12.1988Y2.6642Z-0.0088
X12.2015Y2.6657Z-0.0095
X12.2030Y2.6663Z-0.0105
X12.2084Y2.6674Z-0.0155
X12.2232Y2.6681Z-0.0376
X12.2240Y2.6748Z-0.0363
X12.2273Y2.6913Z-0.0356
X12.2383Y2.7399
X12.2393Y2.7459Z-0.0364
X12.2397Y2.7524Z-0.0382
X12.2436Y2.7631Z-0.0356
X12.2530Y2.8050Z-0.0359
X12.2542Y2.8112Z-0.0363
X12.2551Y2.8192Z-0.0378
X12.2796Y2.8400Z-0.0043
Z0.5000
G0X12.2070Y2.8302
G1Z0.0000F12.0
X12.2128Y2.8340Z-0.0079F35.0
X12.2244Y2.8333Z-0.0104
X12.2298Y2.8324Z-0.0125
X12.2346Y2.8311Z-0.0152
X12.2434Y2.8273Z-0.0226
X12.2506Y2.8227Z-0.0312
Z0.5000
G0X12.2232Y2.6681
G1Z-0.0376F12.0
X12.2240Y2.6652Z-0.0364F35.0
X12.2252Y2.6629Z-0.0348
X12.2289Y2.6591Z-0.0303
X12.2358Y2.6544Z-0.0227
X12.2401Y2.6525Z-0.0190
X12.2443Y2.6516Z-0.0162
X12.2496Y2.6512Z-0.0130
X12.2557Y2.6517Z-0.0104
X12.2608Y2.6526Z-0.0088
X12.2668Y2.6544Z-0.0080
X12.2735Y2.6618Z0.0000
Z0.5000
G0X11.9694Y2.7563
G1Z0.0000F12.0
X11.9761Y2.7635Z-0.0080F35.0
X11.9817Y2.7652Z-0.0087
X11.9876Y2.7663Z-0.0103
X11.9950Y2.7667Z-0.0131
X12.0008Y2.7662Z-0.0165
X12.0055Y2.7649Z-0.0201
X12.0100Y2.7628Z-0.0242
X12.0168Y2.7576Z-0.0321
X12.0197Y2.7542Z-0.0361
X12.0213Y2.7481Z-0.0379
X12.0296Y2.7472Z-0.0249
X12.0370Y2.7470Z-0.0149
X12.0425Y2.7484Z-0.0090
X12.0443Y2.7493Z-0.0077
X12.0463Y2.7507Z-0.0071
X12.0520Y2.7564Z-0.0072
X12.0578Y2.7611Z-0.0081
X12.0655Y2.7659Z-0.0097
X12.0689Y2.7666Z-0.0115
X12.0742Y2.7659Z-0.0165
X12.0787Y2.7637Z-0.0220
X12.0825Y2.7607Z-0.0278
X12.0845Y2.7582Z-0.0316
X12.0852Y2.7592Z-0.0296
Z0.5000
G0X12.0813Y2.7402
G1Z-0.0360F12.0
X12.0827Y2.7429Z-0.0367F35.0
X12.0844Y2.7496Z-0.0356
X12.0850Y2.7558Z-0.0331
X12.0845Y2.7582Z-0.0315
Z0.5000
G0X12.0768Y2.7367
G1Z-0.0291F12.0
X12.0813Y2.7402Z-0.0360F35.0
X12.0829Y2.7371Z-0.0301
Z0.5000
G0X12.0764Y2.7363
G1Z-0.0281F12.0
X12.0768Y2.7367Z-0.0292F35.0
X12.0718Y2.7351Z-0.0202
Z0.5000
G0X12.0033Y2.6659
G1Z-0.0356F12.0
X12.0194Y2.7380Z-0.0359F35.0
X12.0204Y2.7440Z-0.0366
Z0.5000
G0X11.9776Y2.6453
G1Z0.0000F12.0
X12.0033Y2.6659Z-0.0356F35.0
X12.0198Y2.6453Z0.0000
Z0.5000
G0X11.9342Y2.7264
G1Z-0.0392F12.0
X11.9331Y2.7370Z-0.0369F35.0
X11.9319Y2.7416Z-0.0351
X11.9301Y2.7459Z-0.0326
X11.9252Y2.7541Z-0.0268
X11.9198Y2.7599Z-0.0217
X11.9109Y2.7661Z-0.0155
X11.9061Y2.7682Z-0.0133
X11.9015Y2.7696Z-0.0118
X11.8933Y2.7706Z-0.0106
X11.8833Y2.7699Z-0.0111
X11.8783Y2.7686Z-0.0120
X11.8710Y2.7660Z-0.0142
X11.8618Y2.7608Z-0.0182
X11.8567Y2.7570Z-0.0210
X11.8463Y2.7465Z-0.0279
X11.8417Y2.7402Z-0.0313
X11.8361Y2.7302Z-0.0353
X11.8317Y2.7187Z-0.0384
X11.8285Y2.7033Z-0.0400
X11.8279Y2.6923Z-0.0393
X11.8282Y2.6868Z-0.0383
X11.8289Y2.6815Z-0.0370
X11.8311Y2.6744Z-0.0338
X11.8334Y2.6696Z-0.0307
X11.8374Y2.6633Z-0.0262
X11.8441Y2.6565Z-0.0201
X11.8490Y2.6530Z-0.0167
X11.8557Y2.6498Z-0.0135
X11.8619Y2.6481Z-0.0117
X11.8692Y2.6474Z-0.0107
X11.8767Y2.6478
X11.8821Y2.6489Z-0.0115
X11.8886Y2.6510Z-0.0132
X11.8935Y2.6533Z-0.0151
X11.9053Y2.6615Z-0.0213
X11.9120Y2.6679Z-0.0254
X11.9205Y2.6789Z-0.0316
X11.9252Y2.6872Z-0.0349
X11.9289Y2.6957Z-0.0374
X11.9326Y2.7092Z-0.0396
X11.9339Y2.7180Z-0.0398
X11.9342Y2.7264Z-0.0392
Z0.5000
G0X11.7373Y2.6310
G1Z0.0000F12.0
X11.7169Y2.6524Z-0.0417F35.0
X11.7114Y2.8231Z-0.0800
X11.7054Y2.8287
X11.6949Y2.8373
X11.6839Y2.8443Z-0.0765
X11.6726Y2.8494Z-0.0706
X11.6620Y2.8524Z-0.0677
X11.6490Y2.8551Z-0.0659
X11.6224Y2.8596Z-0.0626
X11.5926Y2.8632Z-0.0601
X11.5625Y2.8655Z-0.0586
X11.5333Y2.8665Z-0.0578
X11.5152Z-0.0573
X11.4824Y2.8654Z-0.0577
X11.4506Y2.8622Z-0.0590
X11.4198Y2.8572Z-0.0619
X11.3872Y2.8497Z-0.0666
X11.3600Y2.8411Z-0.0713
X11.3462Y2.8359Z-0.0749
X11.3310Y2.8296Z-0.0781
X11.3024Y2.8158Z-0.0800
X11.2742Y2.7992
X11.2516Y2.7833
X11.2433Y2.7770
X11.2206Y2.7577
X11.1956Y2.7328
X11.1720Y2.7051
X11.1496Y2.6737
X11.1313Y2.6421
X11.1194Y2.6178
X11.1148Y2.6069
X11.1077Y2.5890
X11.0979Y2.5591
X11.0899Y2.5278
X11.0837Y2.4950
X11.0793Y2.4595
X11.0768Y2.4220
X11.0764Y2.4078
X11.0762Y2.3820
X11.0767Y2.3621
X11.0775Y2.3453
X11.0806Y2.3112
X11.0862Y2.2754
X11.0919Y2.2497
X11.0959Y2.2345
X11.0997Y2.2216
X11.1092Y2.1947
X11.1207Y2.1687
X11.1256Y2.1591
X11.1342Y2.1431
X11.1450Y2.1253
X11.1500Y2.1175
X11.1689Y2.0918
X11.1907Y2.0665
X11.2151Y2.0422
X11.2224Y2.0358
X11.2422Y2.0194
X11.2730Y1.9977
X11.3052Y1.9790
X11.3352Y1.9652Z-0.0795
X11.3646Y1.9543Z-0.0721
X11.3808Y1.9492Z-0.0692
X11.3906Y1.9465Z-0.0670
X11.4245Y1.9389Z-0.0620
X11.4556Y1.9344Z-0.0587
X11.4678Y1.9332Z-0.0583
X11.4848Y1.9320Z-0.0569
X11.5179Y1.9309Z-0.0564
X11.5346Y1.9311
X11.5672Y1.9326Z-0.0572
X11.6031Y1.9360Z-0.0588
X11.6117Y1.9375Z-0.0601
X11.6203Y1.9401Z-0.0633
X11.6332Y1.9465Z-0.0719
X11.6459Y1.9556Z-0.0800
X11.6600Y1.9696
X11.6996Y2.0156
X11.6995Y2.2439
X11.6730Y2.2697
X11.6519Y2.2877
X11.6391Y2.2966
X11.6288Y2.3026Z-0.0750
X11.6146Y2.3090Z-0.0640
X11.6051Y2.3122Z-0.0586
X11.5919Y2.3152Z-0.0535
X11.5053Y2.3281Z-0.0333
Z0.5000
G0X11.7373Y2.6310
G1Z0.0000F12.0
X11.7114Y2.8231Z-0.1000
X11.7054Y2.8287Z-0.0974
X11.6949Y2.8373Z-0.0856
X11.5152Z-0.0573
X11.3024Y2.8158Z-0.0864
X11.2742Y2.7992Z-0.0962
X11.2516Y2.7833Z-0.1000
X11.2433Y2.7770
X11.2206Y2.7577
X11.1956Y2.7328
X11.1720Y2.7051
X11.1496Y2.6737
X11.1313Y2.6421
X11.1194Y2.6178
X11.1148Y2.6069
X11.1077Y2.5890
X11.0979Y2.5591
X11.0899Y2.5278
X11.0837Y2.4950
X11.0793Y2.4595
X11.0768Y2.4220
X11.0764Y2.4078
X11.0762Y2.3820
X11.0767Y2.3621
X11.0775Y2.3453
X11.0806Y2.3112
X11.0862Y2.2754
X11.0919Y2.2497
X11.0959Y2.2345
X11.0997Y2.2216
X11.1092Y2.1947
X11.1207Y2.1687
X11.1256Y2.1591
X11.1342Y2.1431
X11.1450Y2.1253
X11.1500Y2.1175
X11.1689Y2.0918
X11.1907Y2.0665
X11.2151Y2.0422
X11.2224Y2.0358
X11.2422Y2.0194
X11.2730Y1.9977
X11.3052Y1.9790Z-0.0887
X11.5346Y1.9311
X11.6459Y1.9556Z-0.0852
X11.6600Y1.9696Z-0.1000
X11.6996Y2.0156
X11.6995Y2.2439
X11.6730Y2.2697
X11.6519Y2.2877
X11.6391Y2.2966Z-0.0853
Z0.5000
G0X11.4848Y2.3477
G1Z0.0000F12.0
X11.5053Y2.3281Z-0.0333F35.0
X11.4869Y2.3134Z0.0000
Z0.5000
G0X11.6995Y2.2439
G1Z-0.0800F12.0
X11.7384Y2.2815F35.0
X11.7494Y2.2904
X11.7551Y2.2945
X11.7673Y2.3023Z-0.0756
X11.7727Y2.3053Z-0.0705
X11.7832Y2.3102Z-0.0622
X11.7965Y2.3146Z-0.0544
X11.8087Y2.3174Z-0.0499
X11.8798Y2.3278Z-0.0340
X11.8972Y2.3477Z0.0000
Z0.5000
G0X11.6995Y2.2439
G1Z-0.1000F12.0
X11.7494Y2.2904Z-0.0961
X11.7551Y2.2945Z-0.0890
Z0.5000
G0X11.9013Y2.3134
G1Z0.0000F12.0
X11.8798Y2.3278Z-0.0340F35.0
Z0.5000
G0X11.6996Y2.0156
G1Z-0.0800F12.0
X11.7230Y1.9959F35.0
X11.7576Y1.9675Z-0.0743
X11.7908Y1.9407Z-0.0166
Z0.5000
G0X11.6996Y2.0156
G1Z-0.1000F12.0
Z0.5000
G0X11.7169Y2.6524
G1Z-0.0416F12.0
X11.6989Y2.6256Z0.0000F35.0
Z0.5000
G0X11.7114Y2.8231
G1Z-0.0800F12.0
X11.7174Y2.8272F35.0
X11.7710Y2.8631Z-0.0166
Z0.5000
G0X11.7114Y2.8231
G1Z-0.1000F12.0
X11.7174Y2.8272Z-0.0965F35.0
Z0.5000
G0X12.0142Y2.3230
G1Z0.0000F12.0
X12.0363Y2.3378Z-0.0345F35.0
X12.0190Y2.3580Z0.0000
Z0.5000
G0X12.0363Y2.3378
G1Z-0.0345F12.0
X12.0959Y2.3296Z-0.0473F35.0
X12.1093Y2.3270Z-0.0513
X12.1183Y2.3248Z-0.0548
X12.1316Y2.3207Z-0.0617
X12.1473Y2.3146Z-0.0724
X12.1611Y2.3077Z-0.0800
X12.1766Y2.2987
X12.1841Y2.2938
X12.2056Y2.2783
X12.2391Y2.2519
X12.2614Y2.2742
X12.2794Y2.2900
X12.2862Y2.2954
X12.2924Y2.2999
X12.3027Y2.3068
X12.3162Y2.3144Z-0.0727
X12.3256Y2.3185Z-0.0656
X12.3393Y2.3232Z-0.0576
X12.3540Y2.3270Z-0.0514
X12.3682Y2.3298Z-0.0469
X12.4241Y2.3381Z-0.0339
X12.4423Y2.3230Z0.0000
Z0.5000
G0X12.0363Y2.3378
G1Z-0.0345F12.0
X12.1611Y2.3077Z-0.0840
X12.1766Y2.2987Z-0.0996
X12.1841Y2.2938Z-0.1000
X12.2056Y2.2783
X12.2391Y2.2519
X12.2614Y2.2742
X12.2794Y2.2900
X12.2862Y2.2954
X12.2924Y2.2999Z-0.0975
X12.3027Y2.3068Z-0.0857
Z0.5000
G0X12.4457Y2.3580
G1Z0.0000F12.0
X12.4241Y2.3381Z-0.0339F35.0
Z0.5000
G0X12.2391Y2.2519
G1Z-0.0800F12.0
X12.2488Y2.1859F35.0
X12.3387Y1.6538
X12.3414Y1.6406
X12.3450Y1.6275
X12.3495Y1.6146
X12.3549Y1.6018
X12.3757Y1.6041
X12.3946Y1.6076
X12.4116Y1.6122
X12.4266Y1.6179
X12.4397Y1.6248Z-0.0782
X12.4509Y1.6328Z-0.0686
X12.4601Y1.6420Z-0.0629
X12.4674Y1.6524Z-0.0611
X12.7609Y2.1578Z-0.0692
X12.7954Y2.2185Z-0.0713
X12.8044Y2.2349Z-0.0724
X12.8110Y2.2480Z-0.0742
X12.8190Y2.2651Z-0.0785
X12.8238Y2.2768Z-0.0800
X12.8269Y2.2862
X12.8304Y2.2993
X12.8187Y2.3076
X12.8080Y2.3140Z-0.0732
X12.7964Y2.3195Z-0.0637
X12.7833Y2.3241Z-0.0559
X12.7714Y2.3272Z-0.0509
X12.7599Y2.3294Z-0.0474
X12.7117Y2.3367Z-0.0364
Z0.5000
G0X12.2391Y2.2519
G1Z-0.1000F12.0
X12.3387Y1.6538
X12.3414Y1.6406
X12.3450Y1.6275
X12.3495Y1.6146
X12.3549Y1.6018
X12.3757Y1.6041
X12.3946Y1.6076
X12.4116Y1.6122
X12.4266Y1.6179Z-0.0916
X12.8238Y2.2768Z-0.0838
X12.8269Y2.2862Z-0.0890
X12.8304Y2.2993Z-0.0984
X12.8187Y2.3076Z-0.0841
Z0.5000
G0X12.6879Y2.3217
G1Z0.0000F12.0
X12.7117Y2.3367Z-0.0364F35.0
X12.6941Y2.3580Z0.0000
Z0.5000
G0X12.8304Y2.2993
G1Z-0.0800F12.0
X12.8452Y2.3060F35.0
X12.8587Y2.3115Z-0.0771
X12.8747Y2.3170Z-0.0675
X12.8904Y2.3216Z-0.0597
X12.9059Y2.3253Z-0.0535
X12.9226Y2.3285Z-0.0481
X12.9885Y2.3381Z-0.0335
X13.0062Y2.3230Z0.0000
Z0.5000
G0X12.8304Y2.2993
G1Z-0.0984F12.0
X12.8452Y2.3060Z-0.0866F35.0
Z0.5000
G0X13.0103Y2.3580
G1Z0.0000F12.0
X12.9885Y2.3381Z-0.0335F35.0
Z0.5000
G0X12.3549Y1.6018
G1Z-0.0800F12.0
X12.3261Y1.4444F35.0
Z0.5000
G0X12.3549Y1.6018
G1Z-0.1000F12.0
X12.3261Y1.4444Z-0.0884F35.0
Z0.5000
G0X12.2838Y1.3900
G1Z0.0000F12.0
X12.3261Y1.4444Z-0.0800F35.0
X12.3565Y1.3955Z0.0000
Z0.5000
G0X12.2838Y1.3900
G1Z0.0000F12.0
Z0.5000
G0X13.6317Y2.1682
G1Z0.0000F12.0
X13.6394Y2.1648Z-0.0106F35.0
X13.6356Y2.1572Z0.0000
Z0.5000
G0X13.6394Y2.1648
G1Z-0.0106F12.0
X13.6593Y2.1702Z-0.0129F35.0
X13.6668Y2.1714Z-0.0138
X13.6767Y2.1719Z-0.0154
X13.6832Y2.1716Z-0.0168
X13.6896Y2.1706Z-0.0187
X13.6961Y2.1688Z-0.0213
X13.7039Y2.1651Z-0.0253
X13.7093Y2.1609Z-0.0288
X13.7128Y2.1570Z-0.0312
X13.7156Y2.1521Z-0.0326
X13.7168Y2.1484Z-0.0332
X13.7180Y2.1383Z-0.0330
X13.7178Y2.1245
X13.7172Y2.1181Z-0.0339
Z0.5000
G0X13.7176Y2.0700
G1Z-0.0329F12.0
Y2.0684Z-0.0331F35.0
X13.7103Y2.0671Z-0.0210
X13.7008Y2.0659Z-0.0082
X13.6972Y2.0646Z-0.0071
X13.6920Y2.0617Z-0.0084
X13.6814Y2.0579Z-0.0121
X13.6756Y2.0570Z-0.0144
X13.6687Z-0.0171
X13.6596Y2.0591Z-0.0213
X13.6528Y2.0622Z-0.0251
X13.6467Y2.0666Z-0.0293
X13.6420Y2.0722Z-0.0331
X13.6400Y2.0765Z-0.0345
X13.6390Y2.0833Z-0.0346
X13.6391Y2.0872Z-0.0343
X13.6396Y2.0902Z-0.0335
X13.6424Y2.0963Z-0.0302
X13.6481Y2.1033Z-0.0241
X13.6554Y2.1093Z-0.0186
X13.6628Y2.1130Z-0.0150
X13.6733Y2.1159Z-0.0125
X13.6830Y2.1174Z-0.0116
X13.6990Y2.1181Z-0.0113
X13.7172Z-0.0339
X13.7178Y2.1114Z-0.0329
X13.7176Y2.0700
Z0.5000
G0Y2.0684
G1Z-0.0331F12.0
X13.7188Y2.0660Z-0.0319F35.0
X13.7217Y2.0630Z-0.0280
X13.7276Y2.0592Z-0.0213
X13.7348Y2.0562Z-0.0149
X13.7422Y2.0552Z-0.0105
X13.7531Y2.0559Z-0.0066
Z0.5000
G0X13.7713Y2.1687
G1Z-0.0060F12.0
X13.7896Y2.1678Z-0.0125F35.0
X13.7945Y2.1668Z-0.0155
X13.8002Y2.1639Z-0.0221
X13.8077Y2.1582Z-0.0343
X13.8079Y2.1372Z-0.0338
X13.8080Y2.0702Z-0.0342
X13.8018Y2.0641Z-0.0236
X13.7938Y2.0584Z-0.0139
X13.7886Y2.0564Z-0.0106
X13.7715Y2.0539Z-0.0065
Z0.5000
G0X13.8080Y2.0702
G1Z-0.0342F12.0
X13.8133Y2.0650Z-0.0251F35.0
X13.8181Y2.0610Z-0.0183
X13.8241Y2.0577Z-0.0127
X13.8289Y2.0563Z-0.0104
X13.8472Y2.0538Z-0.0063
Z0.5000
G0X13.8077Y2.1582
G1Z-0.0343F12.0
X13.8105Y2.1610Z-0.0306F35.0
X13.8140Y2.1660Z-0.0232
X13.8249Y2.1794Z-0.0043
Z0.5000
G0X13.8105Y2.1610
G1Z-0.0306F12.0
X13.8255Z-0.0093F35.0
X13.8297Y2.1619Z-0.0081
X13.8389Y2.1659Z-0.0101
X13.8484Y2.1680Z-0.0134
X13.8551Y2.1681Z-0.0173
X13.8626Y2.1665Z-0.0231
X13.8645Y2.1569Z-0.0168
X13.8656Y2.1471Z-0.0122
X13.8661Y2.1383Z-0.0088
Z0.5000
G0X13.8626Y2.1665
G1Z-0.0231F12.0
X13.8686Y2.1724Z-0.0148F35.0
X13.8776Y2.1803Z-0.0021
Z0.5000
G0X13.8943Y2.1687
G1Z-0.0060F12.0
X13.9126Y2.1678Z-0.0125F35.0
X13.9175Y2.1668Z-0.0155
X13.9231Y2.1639Z-0.0220
X13.9306Y2.1583Z-0.0342
X13.9308Y2.1346Z-0.0338
Y2.0702Z-0.0340
X13.9247Y2.0641Z-0.0236
X13.9170Y2.0584Z-0.0139
X13.9135Y2.0569Z-0.0114
X13.9101Y2.0561Z-0.0100
X13.8944Y2.0539Z-0.0065
Z0.5000
G0X13.9308Y2.0702
G1Z-0.0340F12.0
X13.9404Y2.0613Z-0.0188F35.0
X13.9471Y2.0572Z-0.0119
X13.9515Y2.0559Z-0.0097
X13.9638Y2.0539Z-0.0065
Z0.5000
G0X13.9850Y2.0540
G1Z-0.0066F12.0
X13.9978Y2.0562Z-0.0102F35.0
X14.0039Y2.0588Z-0.0146
X14.0109Y2.0642Z-0.0239
X14.0169Y2.0702Z-0.0341
Y2.1323Z-0.0338
X14.0165Y2.1415Z-0.0342
X14.0147Y2.1517Z-0.0345
Z0.5000
G0X14.0169Y2.0702
G1Z-0.0341F12.0
X14.0246Y2.0627Z-0.0213F35.0
X14.0317Y2.0579Z-0.0130
X14.0369Y2.0560Z-0.0099
X14.0498Y2.0539Z-0.0065
Z0.5000
G0X14.1028Y2.0702
G1Z-0.0341F12.0
X14.1102Y2.0631Z-0.0219F35.0
X14.1177Y2.0580Z-0.0133
X14.1238Y2.0561Z-0.0100
X14.1392Y2.0539Z-0.0064
Z0.5000
G0X13.9335Y2.1611
G1Z-0.0305F12.0
X13.9477Z-0.0099F35.0
X13.9528Y2.1624Z-0.0078
X13.9645Y2.1677Z-0.0102
X13.9719Y2.1697Z-0.0124
X13.9833Y2.1707Z-0.0164
X13.9909Y2.1698Z-0.0199
X14.0008Y2.1664Z-0.0255
X14.0066Y2.1627Z-0.0294
X14.0110Y2.1583Z-0.0323
X14.0147Y2.1517Z-0.0346
X14.0322Y2.1588Z-0.0082
X14.0334Y2.1594
X14.0402Y2.1634Z-0.0087
X14.0481Y2.1670Z-0.0100
X14.0561Y2.1694Z-0.0120
X14.0663Y2.1708Z-0.0154
X14.0767Y2.1699Z-0.0198
X14.0836Y2.1678Z-0.0236
X14.0885Y2.1654Z-0.0267
X14.0934Y2.1619Z-0.0299
X14.0959Y2.1593Z-0.0318
X14.0989Y2.1552Z-0.0335
X14.1012Y2.1490Z-0.0343
X14.1020Y2.1449Z-0.0344
X14.1027Y2.1318Z-0.0338
X14.1028Y2.0702Z-0.0341
X14.0969Y2.0642Z-0.0239
X14.0898Y2.0588Z-0.0146
X14.0837Y2.0562Z-0.0102
X14.0708Y2.0540Z-0.0066
Z0.5000
G0X13.9306Y2.1583
G1Z-0.0343F12.0
X13.9335Y2.1611Z-0.0305F35.0
X13.9370Y2.1661Z-0.0230
X13.9479Y2.1794Z-0.0042
Z0.5000
G0X14.1583Y2.0561
G1Z0.0000F12.0
X14.1713Y2.0630Z-0.0191F35.0
X14.1699Y2.0878Z-0.0079
Z0.5000
G0X14.1713Y2.0630
G1Z-0.0190F12.0
X14.1743Y2.0601Z-0.0157F35.0
X14.1780Y2.0573Z-0.0129
X14.1809Y2.0563Z-0.0120
X14.1933Y2.0540Z-0.0115
X14.2035Y2.0534Z-0.0116
X14.2120Y2.0538Z-0.0118
X14.2191Y2.0550Z-0.0125
X14.2284Y2.0581Z-0.0144
X14.2328Y2.0605Z-0.0159
X14.2387Y2.0652Z-0.0193
X14.2443Y2.0726Z-0.0243
X14.2461Y2.0770Z-0.0269
X14.2472Y2.0827Z-0.0295
X14.2467Y2.0893Z-0.0317
X14.2451Y2.0944Z-0.0326
X14.2431Y2.0975Z-0.0328
X14.2391Y2.1018Z-0.0319
X14.2331Y2.1059Z-0.0311
X14.2248Y2.1101Z-0.0303
X14.1979Y2.1197Z-0.0301
X14.1898Y2.1232Z-0.0302
X14.1838Y2.1269Z-0.0304
X14.1799Y2.1307
X14.1765Y2.1373Z-0.0291
X14.1756Y2.1415Z-0.0277
X14.1754Y2.1470Z-0.0261
X14.1766Y2.1533Z-0.0237
X14.1775Y2.1555Z-0.0225
X14.1795Y2.1593Z-0.0206
X14.1826Y2.1629Z-0.0183
X14.1905Y2.1689Z-0.0147
X14.1982Y2.1720Z-0.0130
X14.2036Y2.1734Z-0.0121
X14.2162Y2.1748Z-0.0116
X14.2270Y2.1744
X14.2385Y2.1729Z-0.0122
X14.2424Y2.1715Z-0.0133
X14.2476Y2.1676Z-0.0182
X14.2487Y2.1451Z-0.0085
Z0.5000
G0X14.2599Y2.1748
G1Z0.0000F12.0
X14.2476Y2.1676Z-0.0182F35.0
Z0.5000
M02
Some of the cuts on your V-carving are less than 0.5mm deep. You’d probably need to surface your stock on the machine to ensure a decent cut.
It is 1/2 - 1 inch above the piece. So would that still matter?
As an aside, did you resolve your issue with the Z-Axis limit switch?
They are sending me a new wire. But i was able to temporarily ziptie it.
Gotcha.
To recap, your issue is that when you use the BitZero it seems to cut up to an inch above the stock, but when you manually zero it, it works just fine?
If so, can you run through how you zero using the BitZero just in case there’ something there?
Yes when I manually zero it works fine. When i use the bitzero v2 i put the bit that is included with it for getting the zero on. I put it on the corner of the stock. Then I jog it inside the circle on the bitzerov2 then I go to carbide motion select probe. Then select bitzero v2 then I click on the corner option. Then i select begin probing.
I wrote a bit about using/verifying the BitZero here:
If you set the unit fully on a surface and then probe for Z only and then go to Z +6mm where is the endmill relative to the surface which was probed against?
Since you are using the “probe endmill” that came with the BitZero, this means you also have to use the BitSetter in this workflow. If you don’t there is no way to swap the “probe endmill” for the “cutting endmill”.
Can you confirm that you are doing this, and only changing the endmil when prompted?
After the probing is dune. I load my file then follow the prompts. When it says to change the bit to the #302 for example that is when i change it. Then it goes over to the bit setter and does it thing.
That sounds correct. The only thing left to consider is how and when you put the “probe endmill” into the collet. Is it there already when you turn on the machine?
I put the probing endmill into it right before i probe. Now that i read that I’m assuming that is the problem.
Yep… if you are just putting it into the machine without telling Carbide Motion you are changing the tool, it will invalidate the notion of how long the tool in the collet currently is.
The machine will think you’ve set the Z zero with a tool that is protruding out of the collect the exact same distance as the one that last touched the BitSetter.
