When in the middle of a project, you decide to press PAUSE the machine stops x and Y and raises Z. Your options are to START (Continue) or STOP. It would be nice that upon pressing stop, the machine exits the program and allows you to select JOG. As it is, STOP tells the machine to HOME. After pressing PAUSE, options could include STOP, or HOME.
If a Bit Setter is enabled - Upon initializing the machine, it wants to check on the height of the bit. If you start a program, it wants to check the height of the bit.
If on initialize you don’t have a bit in the router, It can cause problems it attempts to check the height and there is not a bit there. There is also not STOP or PAUSE button available so you either crash or you scramble to kill power to the brain.
Seems like the first check bit height is not needed.
If you are having any problem where you would like to disable the bit setter, you have to have a bit setter actuation upon initialization before you can get to a screen to disable the bitsetter.
