The Shapeoko we have worked for one year but after a long time not running, the Z limit switch does not work functionally. When we try to initialize machine, the module move up and down all the time and cannot reach the z limit switch. We have checked all the connection on board, and all the connection should still be right (Since we do not change any thing yet) The LED light on the board is on respectively when we test each XYZ switch one by one. We also check all the trails and make sure there ain’t anything block it. Still have the problem on the Z direction. Could anyone help us on that?
Welcome to the community @walterw! So when you’ve connected the machine, but not yet undergone Initialization, in the settings window, there are No Active Pins?
The above the instructions are correct but for current versions. I don’t think they work with 3.x versions. You can update to 5.13 for CM and 4.74 for CC.
I tried each switch by hand and each limit switch works like in the attached pic. But it still struggles to move towards Z limit switch when I try to initialize the machine.
I checked all the wire color and all motors’ wire connection are correct. It works for one year, so I assume the connection should be right since I did not change any connections at all. I am still curious why it worked before but does not work now.
Contact us at support@carbide3d.com — note the entire history and mention what you’ve checked — do you or a friend have a multimeter to check the wiring.
Since this is a classic belt Z, have you powered off the Shapeoko and manually moved the Z up and down to the limits. If you have any mechanical issues they will not get better with the power on. Additionally have you taken the Z belt off and looked at thoroughly for any missing or damaged teeth. Lastly check you Z motor pulley. There are two set screws and one should be on the flat of the stepper motor. These are very tiny screws and some people replace them with cap screws to make tightening easier and less risk of stripping the tiny set/grub screws.
