Show Hot key 11 12 13 14 15
When you hover over an icon it would helpful if it shows the hot key.
Ill add to this with a question that I couldn’t find an answer to on the forum…
Does a current hot key list exist? If so, would it be possible to share it here?
And an idea:
If you had an open excel file that listed current hot keys and included a workbook for hot key suggestions, we could open and add our suggestions to it for further development. Having said that, it is understandable that opening something if that sort to this size of an audience may not be the most effective solution to this as it may result in redundancy and or confusion at times.
Please and thank you.
See:
https://carbide3d.com/carbidecreate/shortcuts
and I worked up:
If you have an idea for a keyboard shortcut for Carbide Create, suggest it at:
Great stuff. Thanks sir.
