Hi Gary,
Shop is almost complete! I am still waiting on the final building inspection, I got failed because they could not find paperwork on my garage doors that was submitted a year ago, and I was missing two screws on the trim on a man door lol. Inspector should sign off any day now…
I came to the conclusion that I do not want anything that makes uncontrollable mess or dust in the building, I learned this after I cut a few boards and there ends up a layer of dust on everything, even when using a 200 cfm shop vac hookup. So I decided to apply for permits to add a 46x12 shed to be placed the other side of the house to setup all my saws and other equipment, with a closed off rear section with a roll up for the mowers and yard equipment.
Unfortunately the amount of heat and moisture in the South Florida summers will corrode any electronics I put in the shop right now. The 16 foot ceilings are going to be a challenge to keep cool. Once I get my final inspection on the building, I am about to apply for permits and get started on installing two 5 ton air conditioners and a battery system with a backyard solar array for powering them. Might end up having to run three 5 tons, or possibly add a 3 ton mini split. Reality is no CNC machines in the shop for quite a while until this project is completed.
Plan was to have a multi purpose shop and store my boats and some Corvettes and still have room for a extensive mechanical and machining area, when you are building you think you have all this room for whatever you want but reality sets in, 3000 sq ft is not that much! And unfortunately I can’t build much more on this property!
Fun fact, I designed most of my property in Fusion 360, exported it to step for my architect. Used the original house plans as a floor background and sketch built it to scale. If you are planning on building on a property I highly recommend modeling everything first, I made so many changes before final plans.
That’s unfortunate that it’s not available for your sawdust. But gotta protect those Corvettes!!
Very awesome rendering of your property! Looks like there is plenty more room to build on . You’re way better than me. When I was building my house, I did a basic blueprint then (I kid you not) I changed every opening on the main floor at least 1x .
Hopefully you are able to get to woodworking again soon.
I’m afraid my 3d printer has become an addiction problem. I’m afraid I feel like if it’s not running… well, it should be! I get home each night and change out the project that is on it and start a new one. Hopefully if it’s small enough I start another one before I go to bed. And then in the morning before work I get that project off and start another. I haven’t gotten the courage up to ask my wife to remove a project so I can start even another in the middle of the work day (all those videos “Proving to my wife that the 3d printer wasn’t a waste of money” come to mind).
Anyway, it HAS helped me upgrade my shop much faster than if I didn’t have it. My French cleat wall has started to get stuff on it.
My “shop” is half a garage. It’s get’s pretty tight in the winter, one bay has the Miata and a snowblower moves in to the “shop” side. It makes for no “layout” space.
But it makes no sense for me to upsize. If I had more space I would have more “stuff” that I don’t really need. I would feel guilty about not making money. It works for me.
Yeah… I grew up with a dad that had a wood shop that we spent so much time in. I desperately wanted a shop when we had our own house and land (even if the total land we own is .7 acres ). It took well over five years from breaking ground to have something that was usable as a shop.
When I finally got a finished shiny building I went to my wife and asked her what we could do to make money from the shop. Yes…I felt guilty having a nice sized shop without it making money.
It’s done pretty well for us I would say making signs.
Now to convince her we need another shed so I can buy an 8n tractor to refurbish. (Hint… that will NEVER happen!)
I’ve shown this in an N4 thread but might as well drop it here too. It is the living room of a 1-bedroom apartment. I specifically asked for ground floor with laminate flooring rather than carpet. My wife (who is staying with one of our daughters in California for health reasons and has never seen the apartment) said “you’re living in a mancave”. I had never thought about it that way…
On the right is the N4 in its sound enclosure of two layers of drywall glued with cheap, water-based carpet adhesive (no fasteners), sitting on two layers of Harbor Freight exercise foam. To its left are the CNC PC (CM, iosender and Orca Slicer are the only installed software), 5C-spindle Taig 4029CREXT CNC lathe with Chinese sewing machine servomotor driving the spindle, and the Elegoo Neptune 4 Pro 3D printer in its tent. Then the “workbench” area. The Amazon-sourced arch light is the best close-in workbench light I’ve used. Full 180° of lighting
Well, for a one and a half to 2 inch sheet of HDU two is super handy. And you can readjust pretty easily. I’m able to handle a one and a half inch sheet of HDU fairly easily and place it on a table without any help.
I’ve shown my “shop” before but since in a few weeks the garage will double as a shop/garage again for the winter I’d show how it looks today. I have two workbenches on casters so I can push them off to the side when the car has to be inside. One bench has my SO4XL with 65mm spindle and HDZ upgrade and the other has a 13" planer and compound miter saw.
Thats why I moved it all to the basement… well half of it anyways, I sold the other half of the haul shortly after I got it. There was wayyyy too much than I could use in my lifetime
@Ed.E They are from a company called MetalTech and sold in hardware stores here in Canada. A quick google search shows their products available at Home Depot in the USA.
I really like the work bench but it does wobble a bit when the spindle is doing short rapid movements. It hasn’t impacted any of my projects but I’m not doing any precision metal work. All my projects are wood. The end frames and cross frames are held together with hitch pins so I drilled and bolted them to add rigidity. I also swapped out the wire bottom shelf with 1/2" plywood.
Nice! How about that laser? That seems like a heavy duty machine! I have not even thought much about laser work in any way. Looks like you can do decent sized work.
