Simple Text Font & toolpath
I’m looking for a way to do text as single lines/curves like Autocad RomanS. I don’t want it to “fill” or pocket the area within the character, just a simple single line/curve. I’m doing a sing with a lot of text on HDPE Black/White/Black.
You will need to set such text in a 3rd party program and then import it.
For a work-around see:
The font ‘Zniko’ is not single line, but is instead extremely narrow. Doing a No-Offset Contour on that font works well. Since it is not single line, you can use it like you would any other font in CC.
I use the Hershy Text plugin and Inkscape for this:
https://www.evilmadscientist.com/2011/hershey-text-an-inkscape-extension-for-engraving-fonts/
I think it’s included in Inkscape now. Inkscape saves as SVG which can be imported into Carbide Create.
