Morning!
Before I order more of the single flute cutters from the US - Has anyone sourced any decent ones from the UK/EU? Looking for a good brand that I can get more locally! I cut a lot of metals so they need to be decent.
Cheers
Morning!
Cheers
Thereās some suppliers in this post
APT does some very sensibly priced DLC coated single flute tools for Aluminium which Iāve had plenty of success on 60XX T6 aluminium, they also have other coatings for ferrous metals.
Cutwel has a broader range of ānameā tools but are more expensive as their cutters are from more expensive brands.
HTH
Thatās perfect - thank you!
I did see APT but they looked so cheap that I wasnāt sure if theyād be any good. Good to know youāve had some success with their stuff!
Yep, I wondered the same but Iāve had pretty good results from their single flute DLC and a few other cutters, nothing wrong with them.
I donāt know if the floor finish would be cleaner with an expensive Amana or Lakeshore Carbide cutter, but honestly, toolpaths and coolant / lubricant and chip evacuation are probably the first target before I gripe about the cutter over finish.
I have used both APT and Rennie. I am guessing these are āimport gradeā cutters but both have had good tolerances and results on alu compared with some of the rubbish I have had from āthat well known south american riverā.
