Six ways to round a corner
There are six ways to round a corner in Carbide Create:
  1. Set the corner type to fillet for a Rectangle:
  1. Round the corner using the Corner tool:
  1. Boolean Operations
  1. Node editing by adding in an arc from a circle
Delete what isn’t needed
Node edit the rectangle to open it and put the open points at the ends of the arc:
Delete what isn’t needed:
Select the edited arc and rectangle:
Join Vectors
  1. Directly node edit the rectangle:
Adjust off-curve nodes to achieve desired radius:
Draw in a circle on a template layer:
Drag off-curve nodes to achieve desired shape:
Increase grid fineness if need be:
  1. Inset, then offset:
@WillAdams Very cool study! Some of those methods would make Rube Goldberg proud, but it’s still fascinating to see so many ways to skin a cat. The “new” corner tool really is a nice implementation that simplifies the process of rounding one corner while giving you full control - and the inset/outset method that you introduced a while back is a go-to for me when I want to round all the corners.
Thanks for doing this work!
Gary:
Like you that inside/outside method was an eye opener when Will shared it.
Good tutorial and the various options now available.
Bill
