SO Pro Build, Enclosure, Setup, and Initial Carvings
  • This is the first time I have used a cnc machine although I have done a decent amount of design work in modeling programs such as Solidworks and Autodesk Inventor so I have the background there. I have been wanting to get a cnc machine for years though so I have done a lot of research into things.
Thanks for that information, I believe I have the postprocessor updated now. I will give it a try a little later today.
EDIT:
The change is working now where it delays the start time so the spindle can reach max rpm!
I was thinking about the depth of the cut and I will probably try that out. I pre-emptively ordered a set of 20/25/30° vbits before I started cutting, figuring I could use them for fine details. Those come in next week so I am looking forward to see how those turn out.
