My wife definitely agrees with rule #5:
“Rule #5 — You will be amazed (and embarrassed) at the places you will find little white flecks of HDPE”
Aluminum chips everywhere hehe
I must have missed this. Are those closed loop motors plug and play with the current steppers? Was that why you shifted to the higher voltage PSU?
They’re both nema23 and that’s where the similarities between stock motors and these end. Short answer would be no. Closed loop steppers require drivers with an encoder that detects stepper’s position and corrects it if needed, so theoretically they should never loose steps. Carbide 3d board has built in stepper drivers which means that - while you’re able to replace the motors for bigger ones, it’s often pointless because they’re limited to the voltage and current that driver can supply.
The reason why I went with higher voltage psu is because ball screws require considerably more power to drive them compared to belts. Also, if you look closely I have two PSUs - 24v and 60v. 24v powers bread board and Z axis motor ( because I don’t need 10000mm/min rapids on a z axis), and 60v psu powers x and y motors. 60v psu should handle additional motor, so if I decide that z axis needs to be faster I can buy new external stepper driver.
Hope that makes it a bit more clear.
You forgot one rule: The appropriate number of Shapeoko(N) to own is N+1
I came across that build some time ago, it is next level!
Congrats on getting to the testing phase, your machine looks badass, I can’t wait to see it in action! Your rapids look pretty good, I think on smaller machines 12k mm/min rapids is a decent figure. When you got to 4x8 machines 25k mm/min seems to be what people target.
Absolutely love the attention to details on that build but designing something so intricate takes time. A lot of time.
Thank you. The machine I’m building is specifically designed to cut aluminum so I can’t see myself going above 10k mm/min with 24k spindle anyways. I’m mostly using single and double flute end mills and stay within 3000-6000 mm/min but that might change. What I have to do is add some diagonal bracing to the metal table that the machine is mounted on. Been doing some air cuts yesterday, and the entire thing shakes pretty well near the machine’s top speed.
Until today building this machine, while requiring a lot of work, was rather effortless. Was really excited when spindle cable arrived because was itching to spin this bad boy up and see how the initial cuts will look like. Already knew what settings on the vid have to be adjusted and how to properly wire it, so was supposed to be easy sailing.
Every ring and spade connector on this machine was soldered and properly isolated to make sure that the machine won’t be prone to emi issues. While it doesn’t seem like a lot of work with one cable, doing entire machine this way takes a lot of time.
Ferrite bead on the spindle cable was absolutely unnecessary. Added it to stiffen up the cable around the plug. Plus it looks kinda cool. lol.
Spindle was all setup but before I could fired it up, had to finish plumbing. All the hoses were already in place, all that needed to be done was to connect a step-down converter to the water pump and fans and top it up with coolant.
Didn’t know where to install the buck converter and specifically didn’t want to use double sided tape or any other sketchy method so milled a new back plate, from the remaining polycarbonate and bolted it to the enclosure.
Step down converter was connected to the 24v psu and now is powering all the plumbing equipment.
Couldn’t be happier with all the disco lights on this side of the enclosure, if not for the fact that the water pump is leaking I knew there was a crack around the water fitting but was hoping that plastic welding it would fix it. Well it didn’t! Seller already sent a new unit, but when will it arrive from china, hard to tell. So this is the first disappointment of the day. But the water is circulating so let’s see how the spindle spins for the first time.
Here comes the disappointment #2!!! Decided to go with the 1.5kw spindle because already had a HY 1.5kw VFD. Didn’t realise that the spindle that arrived is rated for 15A.
Kind of ignored any spindle related topics until today, because I already knew how to wire it all up. Besides there was no info on the seller’s website regarding that. My 110v 2.2kw spindle is rated at 8amps so when I noticed that this is almost double i was shocked. I’ve seen 2.2kw 15a spindles but never 1.5kw at such high rating. Needles to say, spindle made two slow turns and the vfd threw out an error code. Yhhhhhh…
So now I’m wondering what should I do. Pick up higher rated vfd, or get a 2.2kw spindle? I’m actually leaning towards 2.2kw spindle with er20 collet but maybe someone has a better idea? Thanks in advance for all the input.
I’m confused at why you don’t like it is rated for 15 amps. 110 volts times 15 amps = 1650 watts, which is pretty close to the 1500 watt ratings. Meanwhile, your “2.2kW” spindle, if it’s only rated for 8 amps, is a far cry from the 2200 watts it should be rated for (110v8A=880 watts and 220c8A=1760 watts).
My E-Stop experience.
I have a 220v VFD/Spindle, everything else is 120, 24, 12. I also use E-Stop as on-off switch.
At first I had 3 switches stacked to one mushroom switch. Two problems, use the E-Stop while machine is running i.e., it’s intended purpose, everything shuts down as you would expect. BUT, the spindle continues to spin for quite awhile. 2nd problem, no easy way to just shut off the VFD/spindle for end mill changes. My preference.
So, two E-Stops on front of cabinet, one for VFD the other for everything else.
Also, if I E-stop the SO3 etc, the spindle stops quickly.
Hope this makes sense. I’m a woodworker not an electrician.
@The_real_janderson That’s exactly what I realized this morning. Had a brain fart yesterday when writing this and decided to simply switch the VFDs between both spindles. Makes me feel pretty stupid now especially after realizing that my 2.2kw spindle is merely an 800W with er20 collet.
Yes it all makes perfect sense. Appreciate input. What I’m probably going to do is install e-stop as a replacement on/off switch for the power strip and will move it to the front of the enclosure. This should allow me to use it in case of emergency to kill power to spindle and stepper motors. I’m often designing something or researching on the laptop sitting next to the machines and The only reason why I’m consider adding separate switch to the spindle is so I can turn the vfd off to safe myself from this pesky loud fan. Also killing the motors will stop machine’s movement immediately so I don’t really care how long will it take the spindle to coast to a complete halt, since it’s not ploughing through the material anymore.
Back to the spindle problems.
I’ve tried switching VFD’s and running this 110v 1.5kw 15A spindle of a 2.2kw 110v HuyanYang VFD but it’s a no go. VFD will only generate max of 11A (1.5kw VFD max 7A) and I’m getting an overload warning - A.oL or something similar. For a moment thought that maybe the spindle is broken but checked the resistance between each pair of phases (U-V, U-W, V-W) and they all read 0.5ohm. So the motor is good and it’s incredibly frustrating because I’d love to start cutting on this machine but I cant.
What’s the best possible solution that I have? I’ve narrowed it down to those options so please correct me if I’m saying something that makes no sense.
I could get a new motor that is rated at max 11 amps and runs on 110v. So in that case I’m ending up again with a motor thats around 1000W.
Or I could get a 220v 2.2KW spindle and VFD kit and for the time being try using it with the inverter. Double checked and all the power outlets are wired for 15A so should I be worried that the VFD will be tripping the breaker? If anyone has a better solution I’d appreciate any input.
could it be a setting in the VFD parameters that is set too low, and triggering the overload warning ?
I got this one [https://www.amazon.com/gp/product/B07BBHJMQB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
For my Water cooled system that I posted above. Only issue is the DAMM fans
WHAT A JOKE!! So first thing I do is remove the fan inside the controller and
mount a nice quiet fan right on top of the unit, very clear. Also have BIG red button to cut everything off right up front.
Which setting specifically could it be? Technically The only parameters that I should change are the ones that specifically relate to the spindle. So the input voltage and current. Believe all the other settings are the same.
Thank you but this isn’t going to work for me since it has only er11 collet. I’ve bunch of 3/8 and 10mm end mills.
Yeah that was only a wild guess, I was thinking of various params on my VFD like
PD120 = VFD over-current protection, and a few other “over-XXX detection”, that may or may not be enabled, and may or may not be set at (too) low threshold values.
I’m surprised the VFD would generate an “overload” just for starting the motor. Sure, inrush current is a thing, but drawing more than 7A during a long enough time to trip an overload protection?
Maybe dump all of your VFD params (yes, it’s a boring task), and post them there, in case someone spots a param that’s not correctly set to match your spindle ? At least just before you bite the bullet and buy something else.
Which specific A.oL code is it ?
My Huanyang Vfd has these; "E.OL.A ", “E.OL.n”, “E.OD.d” and next to that it says:
E.OL.A - that’s what I was getting.
Worth noting that yesterday when I tried running it of 1.5kw VFD it wouldnt move at all. Today after connecting to 2.2kw VFD and increasing PD142 to 11A it would start to slowly spin and throw out an error code around 3-4k rpm. Also both VFDs are fully functional without cable attached to the spindle.
And I’m using those settings:
PD006=15
PD007=20
PD008=120
PD009=15
PD010=8
tbh these are the settings that I found on a cnczone and they worked perfect for me so far
This is what’s happening to the spindle with 1.5kw VFD set at 7A. It would slowly spin for a few more seconds with the 2.2kw VFD set at 11A.
EDIT I’m at a loss here. My 8.5A spindle draws about 2.5A at 24kr pm under no load. This 1.5kw spindle immediately tries to go all the way up to 15A and shuts down the VFD. Is that normal for the spindle to be drawing full current it’s rated on under no load? I’m assuming not? What could be the culprit? I’ve checked all the wire connections and everything looks nice and clean no visible potential for short anywhere.
