Solid Edge CAM Pro, and postprocessing troubles
hello every one, i found this post about the trouble im having, but it’s closed for new reply
https://community.carbide3d.com/t/siemens-nx-cam-pro-solid-edge-cam-pro-and-gcodes/57811
it’s my first touch with SE CAM Pro and with a CNC ROUTER.
i made a DIY router, i run the machine once with .NC file from Easel, it worked well
but with GRBL generic postprocessing file from Post Hub the machine didn’t even made a move
I also didn’t find out how to export de .NC file, i saved de CAM Pro gerated gcode as .TXT then change it manually for .NC
is there any way to get the output file in .NC format from SE CAM Pro?
Does anyone have a postprocessing file for CAM Pro that works with GRBL?
thanks guys
i apreciate if someone can help me.
I don’t use Solid Edge, but my primary job is working on NX. I think they use the same posts.
I have a NX post for my HDM. I know I created one for an XXL, but can’t find it.
No worries, we can always modify the HDM post if necessary.
You’re welcome to it.
shapeoko_hdm.zip (40.5 KB)
Let me know if anything has to change.
